TP LINK TL-MR6500V 300Mbps Wireless N 4G LTE Router
Quicklinx: G6WHWS00 Mfr#: TL-MR6500V
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Fast Ethernet + 3 more
Speed: 300Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
14 In Stock
£80.99 ex VAT
£97.18 inc VAT
Plug and Play, No Configuration
With an integrated 4G LTE modem and a built-in SIM card slot, all you need to do is insert a micro SIM card and turn on the router. Enjoying fast, stable WiFi on a 4G LTE network has never been easier.
Enjoy WiFi and Phone Calls Simultaneously
TL-MR6500v is not only a WiFi router and modem combo, but also a phone. It has a phone port to connect your existing landline phone so that you can make phone calls and surf the internet at the same time. Moreover, various voice functions are supported including VoIP, VoLTE, and CSFB. Simply enjoy a professional and high-quality voice call as you like.
Special Design for Maximum Network Coverage
Two detachable advanced antennas reinforce the wireless connection between the router and every device with more stability and flexibility. A built-in power amplifier and low noise amplifier also help provide wider coverage by improving the router’s sending and receiving capabilities.
  • Plug-and-Play, no configuration
    With an integrated 4G LTE modem and a built-in SIM card slot, all you need to do is insert a micro SIM card and turn on the router. Enjoying fast, stable Wi-Fi on a 4G LTE network has never been easier.
  • Share Wi-Fi over a 4G network - flexible and stable
    Simply build your home Wi-Fi network via 4G broadband access with download speeds of up to 150 Mbps. You can share the Internet with multiple Wi-Fi devices to enjoy uninterrupted HD movies, rapid file downloads, seamless video chats, and more at the same time.
  • Enjoy Wi-Fi and phone calls simultaneously
    TL-MR6500v is not only a Wi-Fi router and modem combo, but also a phone. It has a phone port to connect your existing landline phone so that you can make phone calls and surf the Internet at the same time. Moreover, various voice functions are supported including VoIP, VoLTE, and CSFB. Simply enjoy a professional and high-quality voice call as you like.
  • Built-in storage for voicemail
    Instead of paying for a voicemail service from your ISP, get free access if you own this modem/router/phone combo. With 50 MB of Internet storage, TL-MR6500v records 100 minutes of voicemail. Never worry about missing any calls or messages when away from home.
  • Special design for maximum network coverage
    Two detachable advanced antennas reinforce the wireless connection between the router and every device with more stability and flexibility. A built-in power amplifier and low noise amplifier also help provide wider coverage by improving the router's sending and receiving capabilities.
  • Used for up to 32 devices with superior stability
    Easily share a 3G/4G connection with up to 32 wireless devices, such as phones, tablets, and laptops, at the same time. 3 LAN ports stand ready to provide Internet for wired devices like desktop computers, printers, and more.
  • Available WAN connection backup
    With a fully functional WAN/LAN port, TL-MR6500v also works as a router which is compatible with cable, fiber, and DSL modem. Its WAN and 3G/4G failover backup strategy keeps a sustained Internet connection no matter your situation.
TP-Link TL-MR6500V - V1 - wireless router - WWAN - Wi-Fi 5 - desktop
Wireless router - wireless cellular modem - 3-port switch (integrated)
Enclosure Type
Desktop
Mobile Communication Protocol
UMTS, HSPA, HSPA+, DC-HSPA+, FDD LTE, TDD LTE
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
Performance
Channel bandwidth (2.4 GHz): 300 Mbps , Channel bandwidth (5 GHz): 867 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, IPv4, IPv6
Routing Protocol
Static IP routing
DHCP support, SPI, WMM support, QoS, virtual server support, WPS, WAN failover, DHCP server, port forwarding, reset button, port triggering, IP-MAC binding, DHCP client, DoS, DHCP reservation, Wireless Scheduler, domain filter, dual band, DMZ support, DynDNS, WPS button, 3G/4G router mode
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
17.4 cm x 12.45 cm x 3.35 cm
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8/8.1/10
Wireless router - 3-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
Performance
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, Plug and Play, RoHS
Communications
Wireless cellular modem
Data Compression Protocol
RFC3261, RFC3550, RFC1889
IP Telephony
Voice Codecs
G.729ab, G.726, G.711A/µ
LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
Expansion Slots
1 (total) / 1 (free) x Micro-SIM
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
Installed Qty
1
1 x network cable
17.4 cm
12.45 cm
3.35 cm
10 - 90% (non-condensing)
Standards: IEEE 802.11a
Standards: IEEE 802.11g
Standards: Fast Ethernet
Standards: IEEE 802.11n
Standards: Ethernet
Standards: IEEE 802.11ac
Speed: 300Mbps
Brand: TP LINK
