Plug and Play, No Configuration
With an integrated 4G LTE modem and a built-in SIM card slot, all you need to do is insert a micro SIM card and turn on the router. Enjoying fast, stable WiFi on a 4G LTE network has never been easier.
Enjoy WiFi and Phone Calls Simultaneously
TL-MR6500v is not only a WiFi router and modem combo, but also a phone. It has a phone port to connect your existing landline phone so that you can make phone calls and surf the internet at the same time. Moreover, various voice functions are supported including VoIP, VoLTE, and CSFB. Simply enjoy a professional and high-quality voice call as you like.
Special Design for Maximum Network Coverage
Two detachable advanced antennas reinforce the wireless connection between the router and every device with more stability and flexibility. A built-in power amplifier and low noise amplifier also help provide wider coverage by improving the router’s sending and receiving capabilities.
Plug-and-Play, no configuration
With an integrated 4G LTE modem and a built-in SIM card slot, all you need to do is insert a micro SIM card and turn on the router. Enjoying fast, stable Wi-Fi on a 4G LTE network has never been easier. -
Share Wi-Fi over a 4G network - flexible and stable
Simply build your home Wi-Fi network via 4G broadband access with download speeds of up to 150 Mbps. You can share the Internet with multiple Wi-Fi devices to enjoy uninterrupted HD movies, rapid file downloads, seamless video chats, and more at the same time. -
Enjoy Wi-Fi and phone calls simultaneously
TL-MR6500v is not only a Wi-Fi router and modem combo, but also a phone. It has a phone port to connect your existing landline phone so that you can make phone calls and surf the Internet at the same time. Moreover, various voice functions are supported including VoIP, VoLTE, and CSFB. Simply enjoy a professional and high-quality voice call as you like. -
Built-in storage for voicemail
Instead of paying for a voicemail service from your ISP, get free access if you own this modem/router/phone combo. With 50 MB of Internet storage, TL-MR6500v records 100 minutes of voicemail. Never worry about missing any calls or messages when away from home. -
Special design for maximum network coverage
Two detachable advanced antennas reinforce the wireless connection between the router and every device with more stability and flexibility. A built-in power amplifier and low noise amplifier also help provide wider coverage by improving the router's sending and receiving capabilities. -
Used for up to 32 devices with superior stability
Easily share a 3G/4G connection with up to 32 wireless devices, such as phones, tablets, and laptops, at the same time. 3 LAN ports stand ready to provide Internet for wired devices like desktop computers, printers, and more. -
Available WAN connection backup
With a fully functional WAN/LAN port, TL-MR6500v also works as a router which is compatible with cable, fiber, and DSL modem. Its WAN and 3G/4G failover backup strategy keeps a sustained Internet connection no matter your situation.
- TP-Link TL-MR6500V - V1 - wireless router - WWAN - Wi-Fi 5 - desktop
- Wireless router - wireless cellular modem - 3-port switch (integrated)
- Enclosure Type
- Desktop
- Mobile Communication Protocol
- UMTS, HSPA, HSPA+, DC-HSPA+, FDD LTE, TDD LTE
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 300 Mbps
- Performance
- Channel bandwidth (2.4 GHz): 300 Mbps , Channel bandwidth (5 GHz): 867 Mbps
- PPTP, L2TP, IPSec, PPPoE, IPv4, IPv6
- Routing Protocol
- Static IP routing
- DHCP support, SPI, WMM support, QoS, virtual server support, WPS, WAN failover, DHCP server, port forwarding, reset button, port triggering, IP-MAC binding, DHCP client, DoS, DHCP reservation, Wireless Scheduler, domain filter, dual band, DMZ support, DynDNS, WPS button, 3G/4G router mode
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
- 17.4 cm x 12.45 cm x 3.35 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8/8.1/10
- Wireless router - 3-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 300 Mbps
- Performance
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, Plug and Play, RoHS
Communications
- Wireless cellular modem
- Data Compression Protocol
- RFC3261, RFC3550, RFC1889
IP Telephony
- Voice Codecs
- G.729ab, G.726, G.711A/µ
- LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x Micro-SIM
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- Installed Qty
- 1
- Cables Included
- 1 x network cable
- OS Required
- 17.4 cm
- 12.45 cm
- 3.35 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
