TP LINK TL-MR6400 300Mbps Wireless N 4G LTE Router
Quicklinx: BWC5WS00 Mfr#: TL-MR6400
Type: Wireless router
Connection Type: WAN/LAN
Standards: Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g + 1 more
Speed: 300Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
More than 50 In Stock
£61.65 ex VAT
£73.98 inc VAT
Take full advantage of your 4G LTE network with the TL-MR6400, which can achieve download speeds of up to 150 Mbps. The TL-MR6400 allows you to share your 4G LTE network with multiple Wi-Fi devices so you can enjoy uninterrupted HD movies, rapid file downloads, and video chats that won't freeze up.
With an integrated 4G LTE modem and a built-in SIM card slot, all you need to do insert a SIM card and turn the router on. Enjoying fast, stable Wi-Fi on a 4G LTE network has never been easier.
TP-Link TL-MR6400 - wireless router - WWAN - Wi-Fi - desktop
Wireless router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Mobile Communication Protocol
GSM, GPRS, UMTS, EDGE, HSPA, HSPA+, LTE, DC-HSPA+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
TCP/IP, PPTP, L2TP, PPPoE, DHCP
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
DoS attack prevention, IPv6 support, VPN passthrough, WDS support, parental control, IP address filtering, WMM support, QoS, WPS, DHCP server, port forwarding, reset button, IPv4 support, SPIF, DHCP client
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
20.2 cm x 14.1 cm x 3.36 cm
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
Communications
Wireless cellular modem
LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
Expansion Slots
1 (total) / 1 (free) x SIM
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
2 x SIM card adapter
1 x network cable
20.2 cm
14.1 cm
3.36 cm
10 - 90% (non-condensing)
BWC5 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 300Mbps
Brand: TP LINK
