Take full advantage of your 4G LTE network with the TL-MR6400, which can achieve download speeds of up to 150 Mbps. The TL-MR6400 allows you to share your 4G LTE network with multiple Wi-Fi devices so you can enjoy uninterrupted HD movies, rapid file downloads, and video chats that won't freeze up.
With an integrated 4G LTE modem and a built-in SIM card slot, all you need to do insert a SIM card and turn the router on. Enjoying fast, stable Wi-Fi on a 4G LTE network has never been easier.
- TP-Link TL-MR6400 - wireless router - WWAN - Wi-Fi - desktop
- Wireless router - wireless cellular modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Mobile Communication Protocol
- GSM, GPRS, UMTS, EDGE, HSPA, HSPA+, LTE, DC-HSPA+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- TCP/IP, PPTP, L2TP, PPPoE, DHCP
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP
- DoS attack prevention, IPv6 support, VPN passthrough, WDS support, parental control, IP address filtering, WMM support, QoS, WPS, DHCP server, port forwarding, reset button, IPv4 support, SPIF, DHCP client
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
- 20.2 cm x 14.1 cm x 3.36 cm
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Routing Protocol
- Static IP routing
- HTTP
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
Communications
- Wireless cellular modem
- LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x SIM
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- Included Accessories
- 2 x SIM card adapter
- Cables Included
- 1 x network cable
- 20.2 cm
- 14.1 cm
- 3.36 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.94 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.76 |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
BWC5 050949 Condition: Customer return - item has been used and shows signs of use |
£36.45 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
