Take full advantage of your 4G LTE network with the TL-MR6400, which can achieve download speeds of up to 150 Mbps. The TL-MR6400 allows you to share your 4G LTE network with multiple Wi-Fi devices so you can enjoy uninterrupted HD movies, rapid file downloads, and video chats that won't freeze up.
With an integrated 4G LTE modem and a built-in SIM card slot, all you need to do insert a SIM card and turn the router on. Enjoying fast, stable Wi-Fi on a 4G LTE network has never been easier.
- TP-Link TL-MR6400 - wireless router - WWAN - Wi-Fi - desktop
- Wireless router - wireless cellular modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Mobile Communication Protocol
- GSM, GPRS, UMTS, EDGE, HSPA, HSPA+, LTE, DC-HSPA+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- TCP/IP, PPTP, L2TP, PPPoE, DHCP
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP
- DoS attack prevention, IPv6 support, VPN passthrough, WDS support, parental control, IP address filtering, WMM support, QoS, WPS, DHCP server, port forwarding, reset button, IPv4 support, SPIF, DHCP client
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
- 20.2 cm x 14.1 cm x 3.36 cm
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Routing Protocol
- Static IP routing
- HTTP
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
Communications
- Wireless cellular modem
- LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x SIM
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- Included Accessories
- 2 x SIM card adapter
- Cables Included
- 1 x network cable
- 20.2 cm
- 14.1 cm
- 3.36 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
