TP LINK TD-W8961N 300Mbps Wireless N ADSL2+ Modem Router
Quicklinx: FT7NWS00 Mfr#: TD-W8961N
Type: Wireless router
Connection Type: ADSL, ADSL2+, VDSL2 and Fibre
Standards: IEEE 802.11n, IEEE 802.11b, Ethernet, Fast Ethernet + 1 more
Speed: 300Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£15.92 ex VAT
£19.10 inc VAT
TP-LINK's TD-W8961N 300 Mbps Wireless N ADSL2+ Modem Router is an incredibly robust all-in-one device that provides a full rate of ADSL2+ standard with the superb reliability and a cost-effective solution for home and small business. With the TD-W8961N, you can easily create a secure wireless network and share a high-speed Internet connection while access to shared files, music, photos, and printers with multiple computers.
  • One-stop solution
    The TD-W8961N does the work of several networking devices packed into one sleek device. With an ADSL2+ modem, NAT router, 4-port switch and 300 Mbps wireless N access point, this device eliminates the need to purchase multiple devices to access and share a high-speed Internet connection.
  • Incredible wireless performance
    With 300 Mbps 802.11n wireless and 4 Megabit LAN ports, the TD-W8961N is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming.
  • Ideal for multimedia application
    Port VLAN binds specific LAN ports and PVCs for differential services like IPTV. The TD-W8961N's built-in QoS engine provides various QoS policies that help prioritize Internet traffic to enable smooth IPTV streaming and lag-free online gaming. Thus users can experience the benefits of a smooth network connection without worrying about traffic congestion. Combined with IGMP multicast and IGMP snooping features the TD-W8961N makes an ideal solution for multimedia applications.
  • Advanced network security and flexible management
    The TD-W8961N utilizes NAT and SPI (stateful packet inspection) firewalls which inspect the contents of incoming packets before they are allowed in, preventing potential attacks from across the Internet. For added convenience, it supports access control based on Mac addresses, IP addresses, domain names or applications such as MSN or Yahoo Messenger, so that parents and network administrators can establish restricted access policies for children or staff. Aside from web configuration, the TD-W8961N also provides TR-069 and SNMP, which automatically update the device's firmware and other settings when they become available from users' ISP. All of these features help users to enhance their network's security and make network management more flexible.
  • WPS one button security
    To set up their network's security encryption, users need simply to press the WPS button on their TD-W8961N, then push the WPS button or enter the router's PIN code in the wireless client, and it will automatically establish a WPA secure connection. Not only is this faster than normal security setups but more convenient in that users don't need to remember a password!
  • Easy to use
    Even novice users can easily setup their networking products. The device comes with a CD with an easy sSetup assistant that leads you through the setup process step-by-step, and even helps with wireless network settings and security configurations.
TP-Link TD-W8961N - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Permanent virtual circuits (PVC): 8
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, DHCP, DNS, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, Telnet, IPP, SNMP 2c, HTTP
DMZ port, NAT support, VLAN support, IGMP snooping, SPI, DoS attack prevention, packet filtering, MAC address filtering, URL filtering, IP address filtering, firmware upgradable, ACL support, QoS, virtual server support, IPSec passthrough, DHCP relay, DNS relay, application filtering, SYN Flooding, Ping of Death, proxy firewall, ToS, DSCP support
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
19.5 cm x 13 cm x 3.5 cm
UNIX, Apple MacOS, Linux, Windows 8, Microsoft Windows 98SE/2000/NT/XP/Vista/7
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, SSL, WPA, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.995.1
LAN: 4 x Ethernet 10/100 - RJ-45 , Phone line: 1 x ADSL2+ - RJ-11
Aerial
Aerial
External integrated
Antenna Qty
2
Directivity
Omni-directional
Gain Level
5 dBi
External power adapter
ADSL splitter
1 x phone cable , 1 x network cable
Software Included
Drivers & Utilities
19.5 cm
13 cm
3.5 cm
10 - 90% (non-condensing)
Standards: IEEE 802.11b
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11g
Speed: 300Mbps
Brand: TP LINK
