Window/Door Safeguard - Monitors the opening & closing of windows, doors, cabinets, the fridge, or the mailbox in real time.
Instant App Notification - Is your parcel locked away? Find out immediately with instant notifications.
Smart Action Support - Connect the actions with other smart devices for a welcome return home.
Easy Installation - Mount to nearly any surface with included 3M adhesive. Supports up to 15mm gap
Great Compatibility - Just one part of the integrated Tapo ecosystem.
Tapo Hub Required – Tapo H100 (sold separately).
Know the Status - Stop wondering if you closed all your windows after leaving home. Check on your doors and windows at a glance with the Tapo app.
Long-Lasting Performance - 2-year battery life provides long-lasting convenience. Receive notifications from the Tapo app when the batteries are low and need changing.
All in One App - Experience your next-level smart home with the Tapo line all in a single app. Create a more secure, convenient, and comfortable living space for you and your loved ones.
Box Contents
- Tapo T110
- Quick Start Guide
- Battery CR2032 x1
- 3M adhensive
Know the status
Stop wondering if you closed all your windows after leaving home. Check on your doors and windows at a glance with the Tapo app. -
Turn lights on automatically
Set your smart contact sensor to trigger on the lights when you open your door. -
Go beyond just doors and windows
Place the smart contact sensor elsewhere like your cabinets and drawers for more convenience. -
Instant push notifications
Receive instant alerts on your phone when a door or window is opened unexpectedly. The Hub can sound a siren to warn of danger and deter intruders.
- Tapo T110 V1 - door and window sensor - smart
- Product Type
- Door and window sensor
- Functions
- Light control, alarm control
- Power Source
- Battery
- Connectivity
- Wireless
- Frequency Band
- 863 - 865 Mhz, 868 - 868.6 MHz
- 1-year warranty
- 3.75 cm x 1.23 cm x 6.14 cm
- Product Type
- Functions
- Power Source
- Battery
- Connectivity Technology
- Wireless
- Frequency Band
- Real-time notifications, surface mountable, build-in magnet, LED indicator, sensor/magnet gap (up to 15 mm)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Required
- Hub Compatibility
- Tapo Hub
- Compatible Application
- Tapo app
- Form Factor
- CR2032
- Battery Included
- Required Qty
- 1
- Battery Lifetime
- 1 year
- Included Accessories
- Adhesive strip
- Warranty
- 1-year warranty
- FCC, JRF, NCC, RCM, R-NZ, RoHS, UKCA, VCCI
- 3.75 cm
- 1.23 cm
- 6.14 cm
- 0 °C
- 40 °C
- 10 - 90% RH (non-condensing)
