TP LINK Tapo T110 Smart Contact Sensor
Quicklinx: H43PWS00 Mfr#: Tapo T110
Type: Door and window sensor
Compatible With: [N/A]
Hurry, only 2 left in stock!
£11.66 ex VAT
£13.99 inc VAT
Window/Door Safeguard - Monitors the opening & closing of windows, doors, cabinets, the fridge, or the mailbox in real time.
Instant App Notification - Is your parcel locked away? Find out immediately with instant notifications.
Smart Action Support - Connect the actions with other smart devices for a welcome return home.
Easy Installation - Mount to nearly any surface with included 3M adhesive. Supports up to 15mm gap
Great Compatibility - Just one part of the integrated Tapo ecosystem.
Tapo Hub Required – Tapo H100 (sold separately).
Know the Status - Stop wondering if you closed all your windows after leaving home. Check on your doors and windows at a glance with the Tapo app.
Long-Lasting Performance - 2-year battery life provides long-lasting convenience. Receive notifications from the Tapo app when the batteries are low and need changing.
All in One App - Experience your next-level smart home with the Tapo line all in a single app. Create a more secure, convenient, and comfortable living space for you and your loved ones.
Box Contents
  • Tapo T110
  • Quick Start Guide
  • Battery CR2032 x1
  • 3M adhensive
  • Know the status
  • Turn lights on automatically
    Set your smart contact sensor to trigger on the lights when you open your door.
  • Go beyond just doors and windows
    Place the smart contact sensor elsewhere like your cabinets and drawers for more convenience.
  • Instant push notifications
    Receive instant alerts on your phone when a door or window is opened unexpectedly. The Hub can sound a siren to warn of danger and deter intruders.
Tapo T110 V1 - door and window sensor - smart
Functions
Light control, alarm control
Power Source
Wireless
Frequency Band
863 - 865 Mhz, 868 - 868.6 MHz
1-year warranty
3.75 cm x 1.23 cm x 6.14 cm
Functions
Power Source
Wireless
Frequency Band
Real-time notifications, surface mountable, build-in magnet, LED indicator, sensor/magnet gap (up to 15 mm)
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Tapo Hub
Compatible Application
Tapo app
CR2032
Battery Included
Required Qty
1
Battery Lifetime
1 year
Adhesive strip
Warranty
1-year warranty
FCC, JRF, NCC, RCM, R-NZ, RoHS, UKCA, VCCI
3.75 cm
1.23 cm
6.14 cm
10 - 90% RH (non-condensing)
Brand: TP LINK
