TP LINK Tapo T100 Smart Motion Sensor
Quicklinx: H43NWS00 Mfr#: Tapo T100
Type: Motion sensor
Compatible With: [N/A]
13 In Stock
£14.16 ex VAT
£16.99 inc VAT
Wide Range Detection – Captures motion up to 23 ft.(7m) away and through 120° view.
Motion-Activated Light – Control smart lights based on your movement and schedule.
Energy Saving – Automatically turn on connected smart devices when you come and go.
Instant Alerts & App Notification – Alerts you in Away Mode for anything you want to know.
Battery-Powered – Compact battery-powered design supports over one year of use.
Easy Installation – Mount it by attached 3M adhesive or the build-in magnets.
Tapo Hub Required – Tapo H100 (sold separately).
  • Hands-free control
    No more fumbling in the dark. Your hallway or bedroom lights turn on automatically as you pass by the sensor without having to flip a switch or say a word.
  • Motion control an entire room
    Create a Smart Action to automate your smart devices and activate them all with motion. Customize your own Smart Actions to group your Tapo products together any way you want.
  • Guard your home while you're away
    The motion sensor can trigger an alarm to deter intruders if it notices anything amiss when you're not home. Receive a notification on your phone as soon as motion is detected.
  • Adjustable sensitivity
    The sensor captures motion up to 7 meters away with a 120° field of view. Adjust the sensitivity to 3 different levels to tailor your detection coverage and filter out false triggers.
  • Flexible sensor angle
    Freely rotate the sensor to the ideal angle and adjust the detection zone to avoid accidental activations by your fur babies.
Tapo T100 V1 - motion sensor - smart - Wi-Fi
Motion sensor
Functions
Motion detection, alarm control, light control
Power Source
Wireless - Wi-Fi
Frequency Band
863 - 865 Mhz, 868 - 868.6 MHz
4.23 cm x 3.4 cm x 4.23 cm
Motion sensor
Functions
Power Source
Wireless
Frequency Band
Real-time notifications, LED indicator, adjustable detection sensitivity, magnet mount, power saving
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Tapo Hub
Compatible Application
Tapo app
Motion Sensor
Detection Range
7 m
Detection Angle
120 degree(s)
CR2450
Battery Included
Required Qty
1
Battery Lifetime
2 years
Adhesive strip
Warranty
FCC, JRF, NCC, RCM, R-NZ, RoHS, UKCA, VCCI
4.23 cm
3.4 cm
4.23 cm
10 - 90% RH (non-condensing)
Type: Motion sensor
Brand: TP LINK
