TP Link Tapo Smart WiFi Bulb 2 pack
Quicklinx: GLJMWS00 Mfr#: TAPO L510E(2-PACK)
Type: Light bulb
Compatible With: Google Assistant, Alexa
Hurry, only 3 left in stock!
£11.66 ex VAT
£13.99 inc VAT
Manage the lighting at your fingertips to create the perfect atmosphere in your home at any time with the Tapo L510E smart Wi-Fi lightbulb.
Found your favorite lighting for watching movies? Save it as a setting you can simply select for future movie nights.
Create a regular schedule to turn on/off with the brightness you set and automatically activate your light according to your time zone.
Manage the lights with your voice commands as Tapo works with Amazon Alexa and Google Assistant. Take your phone out for the pocket and open the Tapo app to control your light remotely. Tapo L510E allows you to automatically simulate someone being at home to frighten away unwanted visitors.
Dimmable Adjust with Ease
Dimmable Preset for Convenience
Schedule Set Your Times
Schedule Sunrise and Sunset Modes
Automatically activate your light according to your time zone
Voice Control
Mange the lights with your voice commands as Tapo works with Amazon Alexa and Google Assistant
Remote Control
Away Mode
Automatically simulate someone being at home to frighten away unwanted visitors
No Hub Required
Connect the L510E Light to your home Wi-Fi network, then you are all set. No need for extra hubs or other devices.
Energy Saving
Benefit from the advanced technology, the Tapo L510E Dimmable Lights consume less energy than normal LED lights.
Tapo Ecosystem
With one Tapo app, everything is under your control. Tapo ecosystem is able to turn your home into a truly smart one.
  • Adjust with ease
    Manage the lighting at your fingertips to create the perfect atmosphere in your home at any time.
  • Preset for convenience
  • Set your times
    Create a regular schedule to turn on/off with the brightness you set.
  • Sunrise and sunset modes
    Automatically activate your light according to your time zone.
  • Voice control
    Mange the lights with your voice commands as Tapo works with Amazon Alexa and Google Assistant.
  • Remote control
  • Away mode
    Automatically simulate someone being at home to frighten away unwanted visitors.
Tapo L510E - LED light bulb - E27 - 8.7 W - 2700 K (pack of 2)
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Usage Modes
Sunrise, sunset, away
Socket Type
E27
Wattage
8.7 W
Colour Temperature
2700 K
Luminous Power
806 lumens
Beam Angle
220 degree(s)
Dimmable
Intelligent Assistant
Platform
Tapo
Communications Technology
Wi-Fi
AC 220 - 240 V
Frequency Required
50/60 Hz
Packaged Quantity
Usage Modes
Light Source
LED light bulb
Socket Type
E27
Wattage
8.7 W
Energy Consumption per 1000h
8.7 kWh
Lamp Current
73 mA
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
806 lumens
Beam Angle
220 degree(s)
Warm-Up Time
1 sec
Dimmable
Lifetime
15000 hours
Switch Cycles
15000
Voice control, controlled via Wi-Fi, remote controlled, light scheduling, app-controlled, adjustable colour temperature, Wi-Fi (2.4 GHz) controlled, away mode
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Hub
Not needed
Platform
Tapo
Compatible Application
Tapo app
Wi-Fi
RoHS, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Diameter
60 mm
Length
115 mm
Type: Light bulb
Compatible With: Alexa
Brand: TP LINK
