Extra Bright Smart Light Bulb - With 1055 lumens (75W Equivalent) of crisp, high-quality lighting, Tapo L535E is ideal for any home space requiring brighter lighting Millions of Colours - Easily design scenarios for your daily routine or activities by customizing the light brightness, light temperature, and colours–with millions of hues to choose from via the Tapo app Voice Control - Manage your smart lights with voice commands via Alexa, Siri, or Google Assistant Matter-Certified - With support for the Matter protocol, Tapo L535E can seamlessly interoperate with other certified products across platforms Schedule and Timer - Create a regular schedule to turn on/off with your chosen light effects Voice Control - Manage your smart lights with voice commands via Alexa, Siri, or Google Assistant Remote Control and Away Mode - Instantly turn connected devices on/off wherever you are via the Tapo app. Turn on away mode to simulate someone being at home Energy Monitoring - Monitor your connected devices' real-time power consumption and costs via the Tapo app No Hub Required - Connect directly to your home's secure Wi-Fi network—no need for a hub or extra equipment
Effortless control
With the integration of Smart Wi-Fi technology and compatibility with the Tapo app, controlling your home lighting has never been easier. Adjust brightness, change colors, and set schedules, all from the convenience of your smartphone. -
Voice activation
Enhance your smart home experience with voice-controlled convenience. Compatible with Alexa and Google Assistant, this light bulb allows for easy voice commands, making it simple to adjust settings without lifting a finger. -
Vibrant illumination
Experience lighting like never before with 16 million colors and a wide color temperature range of 2500-6500 K. Whether you're setting the mood or need optimal light for tasks, this bulb adapts to your needs. -
Energy efficient
Designed with an energy efficiency class of E and consuming only 9 kWh per 1000h, this LED light bulb is an eco-friendly choice that doesn't compromise on performance. Enjoy a luminous power of 1100 lumens with just 8.6 W of energy use. -
Long-lasting durability
With a lifetime of 25,000 hours and 15,000 switch cycles, this bulb is built to last. Its quick warm-up time of 1 sec ensures immediate brightness, providing convenience and reliability in your home lighting.
- Tapo Smart L535E - LED light bulb - shape: A60 / A19 - E27 - 8.6 W - 16 million colours - 2500-6500 K
- Recommended For
- Home
- Light Source Type
- LED light bulb
- Usage Modes
- Away
- Shape
- A60 / A19
- Socket Type
- E27
- Wattage
- 8.6 W
- Wattage Equivalent
- 75 W
- Energy Efficiency Class
- E
- Colour of Illumination
- Colour Temperature
- 2500-6500 K
- Luminous Power
- 1100 lumens
- Beam Angle
- 220 degree(s)
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Tapo, Matter
- Communications Technology
- Wi-Fi
- Voltage Required
- 220 - 240 V
- Frequency Required
- 50/60 Hz
- Recommended For
- Home
- Usage Modes
- Away
Light Source
- LED light bulb
- Shape
- A60 / A19
- Socket Type
- E27
- Wattage
- 8.6 W
- 75 W
- E
- Energy Consumption per 1000h
- 9 kWh
- 2500-6500 K
- Colour Rendering Index
- 90
- Luminous Power
- 1100 lumens
- Beam Angle
- 220 degree(s)
- Warm-Up Time
- 1 sec
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 15000
- Voice control, light scheduling, app-controlled, remote controlled, Smart Wi-Fi technology, multicolour
Power Requirements
- Voltage Required
- 220 - 240 V
- 50/60 Hz
- 9.5 Watt
- Power Consumption Stand by
- 0.2 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Platform
- Tapo, Matter
- Compatible Application
- Tapo app
- Wi-Fi
- Voice Controlled
- Indirect
- Package
- Box
- FCC, ETL, DOE, CEC, RCM, SAA, ERP, UKCA
- Diameter
- 60 mm
- Length
- 115 mm
- 65 g
- -15 °C
- 40 °C
