TP LINK Tapo S220 Smart Light Switch 2Gang 1Way
Quicklinx: H43LWS00 Mfr#: Tapo S220
Type: Wireless light switch
Compatible With: Alexa, Google Assistant
Hurry, only 2 left in stock!
£13.33 ex VAT
£15.99 inc VAT
Remote Control
Instantly turn the light on/off wherever you are through the Tapo app.
Voice Control
Manage your switch with voice commands via Amazon Alexa or the Google Assistant.
Schedule
Preset a schedule to automatically manage devices.
Away Mode
Automatically turn the light on and off at different times to give the appearance that someone is home.
Tool-Free Battery Replacement
Easily replace batteries after installation, no need of other tools.
No Neutral Wire Required
Super easy wiring. No neutral wire required.
Hub Required
The Tapo Hub is required to support all smart features.
Enhanced Experience with Smart Actions
With Smart Acitons, your Tapo devices work seamlessly together to create a smarter home. Trigger your switch when motion is detected with the Tapo Motion Sensor.
Part of the Tapo Ecosystem
To experience the full features of your Tapo, connect it to a Tapo Hub (H100) for a truly connected home. Group lights and devices onto one switch to control the entire room with a single tap.
  • Smart connectivity
    The Tapo S220 V1 is IoT-compatible, enabling wireless connectivity through the Tapo Hub, allowing for seamless integration into your smart home network.
  • Versatile lamp compatibility
    This light switch is compatible with various lamp types, including LED, incandescent, compact fluorescent, and fluorescent tube lights, providing flexibility in your lighting choices.
  • Convenient scheduling
    Featuring a schedule function and timer, this switch allows users to set specific times for lights to turn on or off, enhancing energy efficiency and convenience.
  • User-friendly operation
    With away mode functionality, the switch can simulate occupancy by turning lights on and off at random intervals, providing added security when away from home.
  • Environmentally friendly design
    Compliant with RoHS and UKCA standards, the Tapo S220 V1 ensures safe and sustainable operation in your home, prioritizing both performance and environmental responsibility.
Tapo S220 V1 - light switch - smart
Light switch
Gangs Qty
2
Functions
Light control
Power Source
Internet of Things (IoT) Platform
Tapo
Intelligent Assistant
Alexa, Google Assistant - indirect
Wireless
Frequency Band
868 MHz
8.6 cm x 4.1 cm x 8.71 cm
Light switch
Functions
Light control
Gangs Qty
2
Power Source
Lamp Compatibility
Compact Fluorescent Lamp (CFL), Fluorescent Tube Light (FTL), incandescent lamp, LED lamp
Maximum Loads
LED lamp - 600 W , Compact fluorescent lamp - 600 W , Incandescent lamp - 1000 W , Fluorescent tube light - 1000 W , Fan - 50 W
Wireless
Frequency Band
868 MHz
1-way switch, remote access, voice control, schedule function, Away Mode, timer, no neutral required, low-battery reminder
Hub
Required
Hub Compatibility
Tapo Hub
Platform
Tapo
Voice Controlled
Indirect
AAA / LR03
Battery Included
Required Qty
2
Voltage Provided
1.5 V
Battery Lifetime
1 year
2 AAA batteries, 2 mounting screws
Warranty
RoHS, UKCA
8.6 cm
4.1 cm
8.71 cm
10 - 90% RH (non-condensing)
Brand: TP LINK
