TP LINK Tapo S210 Smart Light Switch 1Gang 1Way
Quicklinx: H43KWS00 Mfr#: Tapo S210
Type: Wireless light switch
Compatible With: Alexa, Google Assistant
£11.66 ex VAT
£13.99 inc VAT
Express delivery Order within the next 16 hours for delivery tomorrow
Remote Control
Instantly turn the light on/off wherever you are through the Tapo app.
Voice Control
Manage your switch with voice commands via Amazon Alexa or the Google Assistant.
Schedule
Preset a schedule to automatically manage devices.
Away Mode
Automatically turn the light on and off at different times to give the appearance that someone is home.
Tool-Free Battery Replacement
Easily replace batteries after installation, no need of other tools.
No Neutral Wire Required
Super easy wiring. No neutral wire required.
Hub Required
The Tapo Hub is required to support all smart features.
Enhanced Experience with Smart Actions
With Smart Acitons, your Tapo devices work seamlessly together to create a smarter home. Trigger your switch when motion is detected with the Tapo Motion Sensor.
Part of the Tapo Ecosystem
To experience the full features of your Tapo, connect it to a Tapo Hub (H100) for a truly connected home. Group lights and devices onto one switch to control the entire room with a single tap.
  • Smart connectivity
    The Tapo S210 V1 is compatible with various IoT devices and can be controlled via the Tapo app, providing users with remote access to their lighting system from anywhere.
  • Energy efficient
    Designed to work with a maximum load of 50 W, this light switch is suitable for different lighting setups, ensuring efficient power consumption across various lamp types.
  • Easy installation
    The battery-powered design eliminates the need for complex wiring, making installation simple and hassle-free while maintaining consistent performance.
Tapo S210 V1 - light switch - smart
Light switch
Gangs Qty
1
Functions
Light control
Power Source
Internet of Things (IoT) Platform
Tapo
Intelligent Assistant
Alexa, Google Assistant - indirect
Wireless
Frequency Band
868 MHz
8.6 cm x 4.1 cm x 8.71 cm
Light switch
Functions
Light control
Gangs Qty
1
Power Source
Lamp Compatibility
Compact Fluorescent Lamp (CFL), Fluorescent Tube Light (FTL), incandescent lamp, LED lamp
Maximum Loads
LED lamp - 600 W , Compact fluorescent lamp - 600 W , Incandescent lamp - 1000 W , Fluorescent tube light - 1000 W , Fan - 50 W
Wireless
Frequency Band
868 MHz
1-way switch, remote access, voice control, schedule function, Away Mode, timer, no neutral required, low-battery reminder
Hub
Required
Hub Compatibility
Tapo Hub
Compatible Application
Tapo app
Platform
Tapo
Voice Controlled
Indirect
AAA / LR03
Battery Included
Required Qty
2
Voltage Provided
1.5 V
Battery Lifetime
1 year
2 AAA batteries, 2 mounting screws
Warranty
RoHS, UKCA
8.6 cm
4.1 cm
8.71 cm
10 - 90% RH (non-condensing)
Brand: TP LINK
