TP LINK Tapo S200B Smart Button
Quicklinx: H43SWS00 Mfr#: Tapo S200B
Type: Smart button
Compatible With: Alexa, Google Assistant
36 In Stock
£10.83 ex VAT
£12.99 inc VAT
Smart Actions – Control and set multiple lights, electronics, and other Tapo smart devices with the button.
Customized Actions – Single tap, double tap, and rotating options enable you to trigger multiple actions, from just one button.
One-Click Alarm – Family members can use the device to get help in times of need.
Control From Multiple Locations – Control electrical fixtures from multiple locations with Tapo smart buttons.
Long Battery Life – The battery will last more than one year.
Smart Control with One Click - Don’t bother opening up an app or calling out to your voice assistant. Just click the button and enjoy a quicker and easier way to control your smart lights.
Control the Entire Home with One Button - Pair all your Tapo lights and devices with a single button for simple and handy control. When you’re on the go, activate Away Mode with one click to turn off all your connected devices
A Touch of Security - Emergency help is just a click away. Install the Tapo Smart Button near a tub, toilet, or bedside for always within reach access.
Your New Smart Doorbell - Build your smart doorbell system by installing the Tapo Smart Button on your door and pairing it with your Smart Hub. Mute and unmute notifications with a quick button press on the hub.
  • Smart actions
  • One-click alarm
  • Control from multiple locations
Tapo S200B V1 - smart button
Smart button
Placing / Mounting
Surface-mounting
Functions
Turn electronics on/off, light control, doorbell
Power Source
Wireless
Frequency Band
863 - 865 Mhz, 868 - 868.6 MHz
Supported Host Device OS
iOS, Android
4.35 cm x 1.69 cm x 4.35 cm
Smart button
Functions
Power Source
Placing / Mounting
Surface-mounting
Wireless
Frequency Band
Android 5.0 (Lollipop) or later, iOS 10 or later
Real-time notifications, build-in magnet, customisable actions (tap, double tap, rotate)
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Tapo Hub
Compatible Application
Tapo app
CR2032
Battery Included
Required Qty
1
Battery Lifetime
1 year
Mounting template, anti-slip tape, double-sided tape
FCC, R-NZ, UKCA, RoHS, JRF, VCCI, NCC, RCM
4.35 cm
1.69 cm
4.35 cm
10 - 90% RH (non-condensing)
Type: Smart button
Brand: TP LINK
