TP LINK Tapo RV30 Plus V1 - Vacuum cleaner - robotic
Quicklinx: H8QRWS00 Mfr#: Tapo RV30 Plus
Type: Smart Vacuum
Compatible With: Alexa, Google Assistant
10 In Stock
£416.66 ex VAT
£499.99 inc VAT
  • 4200Pa Hyper Suction - Sweeps away debris sandwiched between gaps and dust hidden in carpets for a deeper, powerful clean.
  • Auto-Empty with 4L Large Dust Bag - Automatically empties the dustbin after cleaning to keep your hands free for up to 70 days.1
  • LiDAR & Gyro Dual Navi System - Accurately maps out your house in minutes, avoids omissions and repeated cleaning, and even works well in the dark.
  • Vacuum and Mop Combo - 3-level electronic mopping tackles sticky messes and kitchen grease for a more thorough clean.
  • Customizable Cleaning - Merge and separate areas, set cleaning schedule, and customize clean modes for each room.
  • 3-Hour Continuous Cleaning - 5000 mAh battery for long-lasting, fade-free suction.3
  • Auto-Charging - Returns to the charging dock automatically when the battery gets low, and then restarts right where it left off.
  • Carpet Auto-Boost - Increases the suction power when moving from a hard floor to a carpet.
  • Voice & Remote Control - Simply send voice commands via smart speakers or control via the Tapo app.
  • Real-time Voice Reporting - Keeps you informed about the robot‘s current status.
  • Hyper suction
    With industry-leading suction power up to 4200 Pa, the Tapo Robot Vacuum is designed for a deeper clean that sweeps away debris sandwiched between gaps and dust hidden in carpets, leaving nothing but a spotless floor.
  • Many days without emptying
    RV30 Plus empties its dustbin automatically after cleaning to keep your hands free. Dust stays out of sight for many days with a disposable extra-large sealed dust bag. Easily swap out the bag in seconds after the system notifies you that it's full. This keeps allergens locked up the entire time.
  • No residue with shortened air duct
    With a tail-suction air duct that is nearly 45% shorter than ordinary bottom-suction ducts and 27000 Pa super-strong suction power, the dock empties in moments, leaving no residue in the bin or on the floor.
  • Reduce untimely noise interference
    Exclusive function is specially designed for the dock to improve user experience. The dock auto-adjusts its emptying duration according to the cleaning time length of the robot to reduce noise. With do-not-disturb mode, it won't auto-empty during nightly cleans for more peaceful sleep.
  • High-precision dual navigation system
    A LiDAR and Gyro dual navigation system serves as the brain of the robot and accurately maps out your house in minutes, avoids omissions and repeated cleaning, and even works well in the dark.
  • Vacuum and mop combo
    Vacuuming sucks up floating dust and mopping tackles sticky messes. Mopping is essential for homes with hard floors that need regular polishing. With an electronic pump, RV30 Plus provides 3 water flows to suit different floor types with consistent and steady water pressure.
  • Large energy-dense battery
    Tapo RV30 Plus provides long time of continuous whole home cleaning every full charge. The robot returns to the charging dock automatically when the battery gets low, and then restarts right where it left off.
  • Obstacle detection and anti-collision
    Combining precision LiDAR navigation and a full suite of various sensors, Tapo RV30 Plus accurately detects common objects to roam around obstacles, under furniture, and along wall edges, all while avoiding falls down stairs and ledges.
  • Quiet cleaning
    Triple noise suppression lowers noise levels down to 55 dB while in use, quieter than a running microwave. Tapo cleans your home without disturbing you or your pets.
  • Child and pet lock
    Tapo RV30 Plus prevents accidental and inconvenient starts with the child and pet lock. You can deactivate the device's physical start button to prevent children or pets from accidentally turning the robot on.
Tapo RV30 Plus V1 - vacuum cleaner - robotic included charger
Vacuum cleaner
Cleaner Type
Robotic
Compatible Floor Type
General purpose
Cleaning Method
Dry, wet
Control Type
Electronic
Communications Technology
Wi-Fi, Bluetooth 4.2
Platform
Google Home
Intelligent Assistant
Google Assistant, Alexa - indirect
Dust Collection
Bagless
Operating Autonomy
3 hrs
Sound Pressure Level (SPL)
60 dB
Voltage
220 - 240 V / 50 Hz
Power Consumption
40 W
Charger
Included charger
34.1 cm x 34.1 cm x 9.5 cm
6.8 kg
2 years
Vacuum cleaner
Cleaner Type
Robotic
Vacuum Cleaner Type
General purpose
Cleaning Method
Dry, wet
Dust Collection
Bagless
Filter Type
HEPA
Dust Capacity
0.35 litre
Tank Capacity
0.3 litre
Suction Pressure
4.2 kPa
Operating Area
360 m²
Room Navigation
Special Features
Adjustable suction, sensor technology, removable brush roll, LiDAR sensor
Settings, Controls & Indicators
Control Type
Electronic
Scheduling Presets
Speed Settings Qty
4
Smartphone Compatible
Internet of Things (IoT)
Platform
Google Home
Voice Controlled
Indirect
60 dB
Included Tools
Side brush (2x), main brush
2 x HEPA filter , Auto-empty/charging station , 2 x Clean Station dust bag , Mop cloth , Reusable wet mopping pad , Cleaning brush , Virtual Wall unit
Power Type
Rechargeable batteries
Operating Autonomy
3 hrs
Included Charger
Included charger
Battery Voltage
16.8 V
Battery Capacity
5000 mAh
Full Charge Time
190 min
Power Consumption
40 W
Power Consumption Details
950W dust collection/cleaning station
Main Voltage
220 - 240 V / 50 Hz
34.1 cm
34.1 cm
9.5 cm
6.8 kg
Warranty
2 years
Type: Smart Vacuum
Brand: TP LINK
