The TP-Link Tapo RV30 Max Plus is a robotic vacuum cleaner designed for efficient cleaning across all floor types. With a bagless dust collection system and a capacity of 0.3 liters, it ensures hassle-free maintenance and easy disposal of dust and debris. This vacuum has a suction pressure of 5.3 kPa and features HEPA H11 filters, making it suitable for capturing pet hair and allergens, creating a healthier living environment.
Equipped with intelligent features such as a LiDAR+IMU dual navigation system and 3D mapping, the Tapo RV30 Max Plus navigates through your home. It adapts its cleaning mode based on the floor type, utilizing auto carpet boost technology for deeper cleaning on thicker surfaces. With a runtime of up to 150 minutes, this vacuum provides an efficient cleaning experience while being compatible with Google Assistant and Alexa for voice control.
Versatile cleaning methods
This vacuum offers both dry and wet cleaning methods, allowing for comprehensive sanitation of various surfaces in one device. -
Advanced mapping technology
Equipped with 3D mapping, the Tapo RV30 Max Plus effectively plans its cleaning route to ensure complete coverage of your home. -
Efficient pet hair removal
Designed to tackle pet hair effectively, the robust suction capabilities and specially designed brushes ensure a deep clean for pet owners. -
Enhanced safety features
With anti-fall technology and a child lock feature, this vacuum prioritizes the safety of your household while in operation. -
IoT compatibility
This vacuum is IoT-compatible and can be easily controlled through Bluetooth and Wi-Fi, providing remote management capabilities via a smartphone.
- Tapo RV30 Max Plus - vacuum cleaner - robotic
- Product Type
- Vacuum cleaner
- Cleaner Type
- Robotic
- Compatible Floor Type
- General purpose
- Cleaning Method
- Dry, wet
- Communications Technology
- Bluetooth 4.2, Wi-Fi 2.4GHz
- Intelligent Assistant
- Alexa, Google Assistant
- Filter Class
- HEPA H11
- Dust Collection
- Bagless
- Operating Autonomy
- 150 min
- Sound Pressure Level (SPL)
- 55 dB
- Voltage
- 220 - 240 V / 50/60 Hz
- Power Consumption
- 45 W
- 33 cm x 33 cm x 10 cm
- 5.4 kg
- 2 years
- Product Type
- Vacuum cleaner
- Cleaner Type
- Robotic
- Vacuum Cleaner Type
- General purpose
- All floors
- Cleaning Method
- Dry, wet
- Dust Collection
- Bagless
- Filter Type
- HEPA
- Filter Class
- HEPA H11
- Dust Capacity
- 0.3 litre
- Tank Capacity
- 0.3 litre
- Suction Pressure
- 5.3 kPa
- Room Navigation
- Special Features
- LiDAR+IMU dual navigation system, IQ+ Smart Cleaning, DeepVac technology, auto carpet boost, 3D mapping, child lock, anti-fall technology, adjustable suction, removable brush roll
- Pet Hair Removal
Settings, Controls & Indicators
- Programmable Cleaning Intervals
- Indicators
- Battery indicator
- Smartphone Compatible
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Directive 2014/53/EU, Directive 2009/125/EC, Directive 2011/65/EU, Directive 2015/863/EU
- 55 dB
- Included Tools
- Side brush, main brush
- Included Accessories
- Self-emptying/charging base , Dust bag (3 l) , Cleaning brush , Power cable , Mopping module , HEPA filter
- Power Type
- Rechargeable batteries
- 150 min
- Battery
- Lithium Ion
- Battery Voltage
- 16.8 V
- Battery Capacity
- 2600 mAh
- Full Charge Time
- 4 hrs
- Power Consumption
- 45 W
- Power Consumption Details
- 650W cleaning/charging base, 10W charging
- Main Voltage
- 33 cm
- 33 cm
- 10 cm
- 5.4 kg
- Warranty
- 2 years
