TP LINK Tapo RV30 Max Plus Smart Vacuum Cleaner
Quicklinx: J1RBWS00 Mfr#: Tapo RV30 Max Plus
Compatible With: Google Assistant, Alexa
23 In Stock
£249.17 ex VAT
£299.00 inc VAT
The TP-Link Tapo RV30 Max Plus is a robotic vacuum cleaner designed for efficient cleaning across all floor types. With a bagless dust collection system and a capacity of 0.3 liters, it ensures hassle-free maintenance and easy disposal of dust and debris. This vacuum has a suction pressure of 5.3 kPa and features HEPA H11 filters, making it suitable for capturing pet hair and allergens, creating a healthier living environment.
Equipped with intelligent features such as a LiDAR+IMU dual navigation system and 3D mapping, the Tapo RV30 Max Plus navigates through your home. It adapts its cleaning mode based on the floor type, utilizing auto carpet boost technology for deeper cleaning on thicker surfaces. With a runtime of up to 150 minutes, this vacuum provides an efficient cleaning experience while being compatible with Google Assistant and Alexa for voice control.
  • Versatile cleaning methods
    This vacuum offers both dry and wet cleaning methods, allowing for comprehensive sanitation of various surfaces in one device.
  • Advanced mapping technology
    Equipped with 3D mapping, the Tapo RV30 Max Plus effectively plans its cleaning route to ensure complete coverage of your home.
  • Efficient pet hair removal
    Designed to tackle pet hair effectively, the robust suction capabilities and specially designed brushes ensure a deep clean for pet owners.
  • Enhanced safety features
    With anti-fall technology and a child lock feature, this vacuum prioritizes the safety of your household while in operation.
  • IoT compatibility
    This vacuum is IoT-compatible and can be easily controlled through Bluetooth and Wi-Fi, providing remote management capabilities via a smartphone.
Tapo RV30 Max Plus - vacuum cleaner - robotic
Vacuum cleaner
Cleaner Type
Robotic
Compatible Floor Type
General purpose
Cleaning Method
Dry, wet
Communications Technology
Bluetooth 4.2, Wi-Fi 2.4GHz
Intelligent Assistant
Alexa, Google Assistant
Filter Class
HEPA H11
Dust Collection
Bagless
Operating Autonomy
150 min
Sound Pressure Level (SPL)
55 dB
Voltage
220 - 240 V / 50/60 Hz
Power Consumption
45 W
33 cm x 33 cm x 10 cm
5.4 kg
2 years
Vacuum cleaner
Cleaner Type
Robotic
Vacuum Cleaner Type
General purpose
All floors
Cleaning Method
Dry, wet
Dust Collection
Bagless
Filter Type
HEPA
Filter Class
HEPA H11
Dust Capacity
0.3 litre
Tank Capacity
0.3 litre
Suction Pressure
5.3 kPa
Room Navigation
Special Features
LiDAR+IMU dual navigation system, IQ+ Smart Cleaning, DeepVac technology, auto carpet boost, 3D mapping, child lock, anti-fall technology, adjustable suction, removable brush roll
Pet Hair Removal
Settings, Controls & Indicators
Programmable Cleaning Intervals
Indicators
Battery indicator
Smartphone Compatible
Internet of Things (IoT)
Directive 2014/53/EU, Directive 2009/125/EC, Directive 2011/65/EU, Directive 2015/863/EU
55 dB
Included Tools
Side brush, main brush
Self-emptying/charging base , Dust bag (3 l) , Cleaning brush , Power cable , Mopping module , HEPA filter
Power Type
Rechargeable batteries
Operating Autonomy
150 min
Lithium Ion
Battery Voltage
16.8 V
Battery Capacity
2600 mAh
Full Charge Time
4 hrs
Power Consumption
45 W
Power Consumption Details
650W cleaning/charging base, 10W charging
Main Voltage
33 cm
33 cm
10 cm
5.4 kg
Warranty
2 years
Compatible With: Alexa
Brand: TP LINK
