- Matter Certified – Integrate Matter-certified Tapo devices with other Matter end products into your preferred ecosystem.
 - Energy Monitoring - Set your electricity rate to estimate your energy bills, offers more comprehensive insights into home appliances' power consumption with more intuitive and straightforward data visualizations.
 - Surge Protection – Surge protection shields sensitive electronics and appliances from sudden power surges that can occur during thunderstorms.
 - Zero-Crossing Detection – Addresses relay contact welding, a key issue in smart plug failures, improves product reliability and load capacity.
 - Voice Control – Manage your smart plug with voice commands via Amazon Alexa, Apple Siri, or Google Assistant.
 - Remote Control – Instantly turn connected devices on/off from wherever you are through the Tapo app.
 - Schedule – Preset a schedule to automatically manage devices.
 - Auto-Off – Automatically turns off a connected device after the device is left on for a set time.
 - Away Mode – Automatically turns devices on and off at different times to give the appearance that someone is home.
 - Tapo P304M V1 - smart power strip
 - Smart power strip - external
- Cord Length
 - 1.5 m
- Input Voltage
 - AC 250 V
- Input Connectors
 - 1 x power
- Platform
 - Apple HomeKit, Google Home, SmartThings, Tapo, Matter
- Intelligent Assistant
 - Siri, Google Assistant, Alexa - indirect
- Networking
 - IEEE 802.11 b/g/n
 - 26 cm x 6.27 cm x 3.14 cm
 - 2-year warranty
- Cord Length
 - 1.5 m
- Input Voltage
 - AC 250 V
- Frequency Required
 - 50/60 Hz
- Input Connectors
 - 1 x power
- Max Electric Current
 - 13 A
- Surge Suppression
- Remote Management Interface
 - IEEE 802.11 b/g/n
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Compatible Application
 - Tapo app
- Communications Technology
 - Wi-Fi
- Voice Controlled
 - Indirect
- Cables Included
 - Power cable - integrated - 1.5 m
 - Flame retardant, remote control, auto on/off, schedule function, away mode, timer, overheat protection, LED indicators, child protection, overload protection, individual switches, zero-crosing detection technology
 - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, RoHS, PC UL94 V0, WPA2-PSK, UKCA, WEP, WPA, WPA2, WPA3, WPA3-SAE
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
 - 10 - 90% RH (non-condensing)
 - 26 cm
 - 6.27 cm
 - 3.14 cm
