TP LINK Tapo P304M
Quicklinx: HVL7WS00 Mfr#: Tapo P304M
£33.33 ex VAT
£39.99 inc VAT
  • Matter Certified – Integrate Matter-certified Tapo devices with other Matter end products into your preferred ecosystem.
  • Energy Monitoring - Set your electricity rate to estimate your energy bills, offers more comprehensive insights into home appliances' power consumption with more intuitive and straightforward data visualizations.
  • Surge Protection – Surge protection shields sensitive electronics and appliances from sudden power surges that can occur during thunderstorms.
  • Zero-Crossing Detection – Addresses relay contact welding, a key issue in smart plug failures, improves product reliability and load capacity.
  • Voice Control – Manage your smart plug with voice commands via Amazon Alexa, Apple Siri, or Google Assistant.
  • Remote Control – Instantly turn connected devices on/off from wherever you are through the Tapo app.
  • Schedule – Preset a schedule to automatically manage devices.
  • Auto-Off – Automatically turns off a connected device after the device is left on for a set time.
  • Away Mode – Automatically turns devices on and off at different times to give the appearance that someone is home.
Tapo P304M V1 - smart power strip
Smart power strip - external
Cord Length
1.5 m
Input Voltage
AC 250 V
Input Connectors
1 x power
Platform
Apple HomeKit, Google Home, SmartThings, Tapo, Matter
Intelligent Assistant
Siri, Google Assistant, Alexa - indirect
IEEE 802.11 b/g/n
26 cm x 6.27 cm x 3.14 cm
Cord Length
1.5 m
Input Voltage
AC 250 V
Frequency Required
50/60 Hz
Input Connectors
1 x power
Max Electric Current
13 A
Surge Suppression
Remote Management Interface
IEEE 802.11 b/g/n
Internet of Things (IoT)
Platform
Compatible Application
Tapo app
Communications Technology
Wi-Fi
Voice Controlled
Indirect
Power cable - integrated - 1.5 m
Flame retardant, remote control, auto on/off, schedule function, away mode, timer, overheat protection, LED indicators, child protection, overload protection, individual switches, zero-crosing detection technology
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, RoHS, PC UL94 V0, WPA2-PSK, UKCA, WEP, WPA, WPA2, WPA3, WPA3-SAE
10 - 90% RH (non-condensing)
26 cm
6.27 cm
3.14 cm
Brand: TP LINK
