Tp-Link Tapo Mini Smart Wi-Fi plug with Energy monitoring
Matter Certified Integrate Matter-certified Tapo devices with other Matter end products into your preferred ecosystem Energy Monitoring - Set your electricity rate to estimate your energy bills offers more comprehensive insights into home appliances' power consumption with more intuitive and straightforward data visualizations Note: Energy Monitoring feature is not supported by Matter yet but coming soon. Please use this feature in the Tapo app for now Compact Design - Mini-sized to avoid blocking adjacent outlets Voice Control Manage your smart plug with voice commands via Amazon Alexa Apple Siri or Google Assistant
                Effortless controlWith voice control compatibility with Alexa, Google Assistant, and Siri, managing your home's devices is as simple as speaking. The Tapo P110M V1 smart plug integrates seamlessly into your smart home ecosystem, allowing for hands-free operation and convenience.
                Enhanced safety featuresDesigned with your family's safety in mind, the Tapo P110M V1 features a child safety shutter, flame-retardant materials, and overload protection. These features ensure a safer home environment by preventing accidents before they happen.
                Smart energy monitoringKeep track of your energy consumption with the Tapo P110M V1's energy use monitor. This smart plug not only allows you to remotely control your devices but also helps you save on electricity bills by providing valuable insights into your energy usage.
                Reliable connectivityEquipped with Wi-Fi and Bluetooth connectivity, the Tapo P110M V1 ensures a stable and reliable connection to your home network. Whether you're using it for the schedule function or remote control, this smart plug keeps you connected to your devices without fail.
                Convenient schedulingThe Tapo P110M V1 smart plug's schedule function and timer offer convenience. Whether you're setting up the lights to turn on before you arrive home or managing your devices' operating hours, this smart plug makes it easy to customize your home's automation.
- Tapo P110M V1 - smart plug - Bluetooth, 802.11b/g/n
- Product Type
- Smart plug
- Environment
- Indoor
- Functions
- Energy use monitor, remote control
- Power Source
- Power socket
- Intelligent Assistant
- Siri, Google Assistant, Alexa - indirect
- Connectivity
- Wireless - Bluetooth, 802.11b/g/n
- Frequency Band
- 2.4 Ghz
- 2-year warranty
- 5.15 cm x 3.06 cm x 7.25 cm
- Product Type
- Smart plug
- Environment
- Indoor
- Functions
- Power Source
- Power socket
- Connectivity Technology
- Wireless - Bluetooth, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 Ghz
- Up to 3680 Watt, Away Mode, voice control, LED indicator, timer, overload protection, flame-retardant, automatic switch-off function, 16 A max load current, schedule function, rust proof, child safety shutter Bluetooth for onboarding only, Matter compatibility
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Compatible Application
- Tapo app
- Communications Type
- Cloud
- Communications Technology
- Wi-Fi
- Voice Controlled
- Indirect
- Product Material
- Polycarbonate
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP, WPA3
- Voltage Required
- AC 100-240 V
- Rated Current
- 13 A
- Warranty
- 2-year warranty
- RoHS, UL 94 V-0, UKCA
- 5.15 cm
- 3.06 cm
- 7.25 cm
- 0 °C
- 40 °C
- 10 - 90% RH (non-condensing)
