TP LINK Tapo P110 Smart plug mini wireless 4 pack
Quicklinx: H57JWS00 Mfr#: TAPO P110(4-PACK)
Type: Smart plug
Compatible With: Google Assistant, Alexa
Hurry, only 1 left in stock!
£27.49 ex VAT
£32.98 inc VAT
Remote Control – Instantly turn connected devices on/off wherever you are through the Tapo app
Schedule – Preset a schedule to automatically manage devices
Timer - Create countdown timer lists for connected electronics
Voice Control – Manage your smart plug with voice commands via Amazon Alexa or the Google Assistant
Away Mode – Automatically turns devices on and off at different times to give the appearance that someone is home
Compact Design - Mini-sized to avoid blocking adjacent sockets
Easy Setup and Use - No hub required, set up quickly and manage easily through the free app
  • Smart control from your mobile device
    Manage your connected devices from anywhere with the Tapo app. It's designed to support your lifestyle and keep your family safe.
  • No internet, no problems
    Control your connected devices through your Tapo app, even when the Internet is down. Your schedules will continue, regardless of connections.
  • Save money and energy
    Monitor real-time power consumption and energy spend via the Tapo app. Save smarter by managing your appliances for when electricity is cheaper.
  • Group devices for one-tap control
    Combine several devices under one group, so your smart plug works with other Tapo smart devices. Turn them all on or off with one action - no need for repeated actions anymore.
  • Mighty features and compact size
    Tapo P110 is built small to leave adjacent sockets open, making it convenient for daily use.
  • Share to families
    Not limited to single control, family members can directly share management permissions with each other, saving time and enhancing user-friendliness.
  • Safety at home, while away
    Away Mode simulates someone being at home. Deter thieves and those of ill intent with plugged-in devices turning on and off at scheduled times.
  • Enjoy easy, friendly setup and use
    Unique onboarding technology makes setup steps simpler for faster connection (within 20 seconds).
Tapo P110 V1 - smart plug - mini - 802.11b/g/n (pack of 4)
Smart plug
Packaged Quantity
4 (specifications are for single item)
Functions
Energy use monitor, turn electronics on/off
Intelligent Assistant
Google Assistant, Alexa - indirect
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
Supported Host Device OS
iOS, Android
5.15 cm x 3.06 cm x 7.25 cm
Packaged Quantity
Smart plug
Functions
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Android 4.4 (KitKat) or later, iOS 9 or later
On / off button, Away Mode, remote access, voice control, LED indicator, timer, flame-retardant, up to 2990 Watt, schedule function, 13 A max load current
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
Wi-Fi
Voice Controlled
Indirect
Product Material
Polycarbonate
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP, WPA3
AC 100-240 V
Warranty
RoHS, PC UL94 V0
5.15 cm
3.06 cm
7.25 cm
10 - 90% (non-condensing)
Type: Smart plug
Compatible With: Alexa
Brand: TP LINK
