TP LINK Tapo P110 Mini Smart Wi-Fi Socket
Quicklinx: GLJ9WS00 Mfr#: TAPO P110
Type: Smart plug
Compatible With: Alexa, Google Assistant
20 left in stock
£9.16 ex VAT
£10.99 inc VAT
Express delivery Delivered on Tuesday
Remote Control – Instantly turn connected devices on/off wherever you are through the Tapo app
Schedule – Preset a schedule to automatically manage devices
Timer - Create countdown timer lists for connected electronics
Voice Control – Manage your smart plug with voice commands via Amazon Alexa or the Google Assistant
Away Mode – Automatically turns devices on and off at different times to give the appearance that someone is home
Compact Design - Mini-sized to avoid blocking adjacent sockets
Easy Setup and Use - No hub required, set up quickly and manage easily through the free app
TP-Link
Internet of Things (IoT)
Aerial
Internal
Type: Smart plug
Brand: TP LINK
Stock Status: While stocks last
Stock Status: Clearance
