Mini Smart Wi-Fi Socket - Pack of 4
Remote Control
Instantly turn connected devices on/off wherever you are through the Tapo app
Schedule
Preset a schedule to automatically manage devices
Timer
Create countdown timer lists for connected electronics
Voice Control
Manage your smart plug with voice commands via Amazon Alexa or the Google Assistant
Away Mode
Automatically turns devices on and off at different times to give the appearance that someone is home
Compact Design
Mini-sized to avoid blocking adjacent sockets
Easy Setup and Use
No hub required, set up quickly and manage easily through the free app
                Live smarter by presetting timeSchedule and Timer features allow you to create weekly schedule and countdown plans. All of your connected electronics will automatically work at your preset time, making your life smart, convenient, and energy-saving.
                Mighty features and compact sizeTapo P100 is built small to leave adjacent sockets open, making it convenient for daily use.
                A deterrent for your homeAway mode, a feature that intelligently simulates someone being home by turning the plugged in device (like a lamp) on and off, makes it appear that someone is home when you're on long trips to keep away people with ill intent.
                Share to familiesNot limited to single control, family members can directly share management permissions with each other, saving time and enhancing user-friendliness for the elderly.
- Tapo P100 V1.2 - smart plug - 802.11b/g/n, Bluetooth 4.2 (pack of 4)
- Product Type
- Smart plug
- Packaged Quantity
- 4 (specifications are for single item)
- Environment
- Indoor
- Intelligent Assistant
- Alexa, Google Assistant
- Connectivity
- Wireless - 802.11b/g/n, Bluetooth 4.2
- Frequency Band
- 2.4 Ghz
- Supported Host Device OS
- Android, iOS
- 5.1 cm x 4 cm x 7.2 cm
- Packaged Quantity
- Product Type
- Smart plug
- Environment
- Indoor
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.2
- Frequency Band
- 2.4 Ghz
- Android 4.3 (Jelly Bean) or later, iOS 9 or later
- Voice control, flame-retardant, up to 13 A, timer, Away Mode, up to 2990 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
Aerial
- Form Factor
- Internal
- Product Material
- Polycarbonate
- Encryption Algorithm
- WPA2-PSK, WPA-PSK, WPA, WPA2
- Nominal Voltage
- AC 220 - 240 V
- RoHS
- 5.1 cm
- 4 cm
- 7.2 cm
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
