- Zonal Color Control - make the most of 50-section addressable color zones, to suit every mood or scenario setting.
- Extra White LEDs - acts as general lights, strengthening the practicability of the colorful Wi-Fi light strip.
- Fancy Lighting Effects - amuse yourself with well-designed animated lighting effects, available on Tapo App.
- Music Sync - adds more vibe by emitting dynamic lights, parallel with the surrounding music beat.
- Apple HomeKit Supported - control your light strip with Siri using Apple HomeKit.
- Voice Control- compatible with your smart voice assistants, including Alexa and Google Assistant.
- Surface Coating-stays durable, tidy, and complete, thanks to the high-quality PU coating on its surface.
- Wi-Fi Connection - with a stable connection to your networks, it works well without hub requirements.
- Easy Setup - attach the Light Strip with 3M Adhesive on desired spots, connect it to Wi-Fi and configure it via App.
                1000 lumens white light for illuminationExtraly-added white LED light beads, spanning over the light strip, emit high-lumen white lighting. It makes Tapo L930-5 an all-rounder, serving diverse illumination purposes.
                50 color segments for zonal controlExert your imagination to set the 50 separate color zones or let it shine to suit your changing moods.
                Crystal, flexible, and cleanTapo L930-5, generates a soft transparent light through its exterior PU coating. It's easy to attach it as the way you want. The high-tech coating protects all the LED beads well and makes it easy to maintain.
                Stir your sense up via music syncL930-5 light strip captures the music going around it, syncing to the frequency and the beat. Keep pace with the rhythm and get all your senses stirred up at a party!
- Tapo L930-5 - light strip - LED - 13 W - 16 million colours
- Product Type
- Light strip
- Light Source Type
- LED
- Usage Modes
- Away
- Wattage
- 13 W
- Colour of Illumination
- Luminous Power
- 1000 lumens
- Dimmable
- Intelligent Assistant
- Alexa, Google Assistant, Siri - indirect
- Platform
- Apple HomeKit
- Communications Technology
- Wi-Fi
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50/60 Hz
- Product Type
- Light strip
- Usage Modes
- Away
- 50 colour zones, cuttable, 3M adhesive tape mounting, power on/off timer, lighting schedules, remote controlled, app-controlled, voice control, flexible, Wi-Fi (2.4 GHz) controlled
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 13 W
- Luminous Power
- 1000 lumens
- Dimmable
- Lifetime
- 50000 hours
- Preset modes, 1%-100% dimmable, music sync, white LED
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50/60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Platform
- Apple HomeKit
- Compatible Application
- Tapo app
- Wi-Fi
- Voice Controlled
- Indirect
- Product Material
- Polyurethane (PU)
- RoHS, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC, JRF, IC, VCCI, RCM, NCC, BSMI
- 1 cm
- 0.3 cm
- Length
- 5 m
- 649 g
- Shipping Dimensions (WxDxH) / Weight
- 23.15 cm x 6.85 cm x 20.45 cm
- -15 °C
- 40 °C
