TP LINK Tapo L930-5 Smart Light Strip - 5mtrs
Quicklinx: H0P1WS00 Mfr#: TAPO L930-5
Type: Light strip
Compatible With: Siri, Alexa, Google Assistant
Hurry, only 2 left in stock!
£29.99 ex VAT
£35.98 inc VAT
  • Zonal Color Control - make the most of 50-section addressable color zones, to suit every mood or scenario setting.
  • Extra White LEDs - acts as general lights, strengthening the practicability of the colorful Wi-Fi light strip.
  • Fancy Lighting Effects - amuse yourself with well-designed animated lighting effects, available on Tapo App.
  • Music Sync - adds more vibe by emitting dynamic lights, parallel with the surrounding music beat.
  • Apple HomeKit Supported - control your light strip with Siri using Apple HomeKit.
  • Voice Control- compatible with your smart voice assistants, including Alexa and Google Assistant.
  • Surface Coating-stays durable, tidy, and complete, thanks to the high-quality PU coating on its surface.
  • Wi-Fi Connection - with a stable connection to your networks, it works well without hub requirements.
  • Easy Setup - attach the Light Strip with 3M Adhesive on desired spots, connect it to Wi-Fi and configure it via App.
  • 1000 lumens white light for illumination
    Extraly-added white LED light beads, spanning over the light strip, emit high-lumen white lighting. It makes Tapo L930-5 an all-rounder, serving diverse illumination purposes.
  • 50 color segments for zonal control
    Exert your imagination to set the 50 separate color zones or let it shine to suit your changing moods.
  • Crystal, flexible, and clean
    Tapo L930-5, generates a soft transparent light through its exterior PU coating. It's easy to attach it as the way you want. The high-tech coating protects all the LED beads well and makes it easy to maintain.
  • Stir your sense up via music sync
    L930-5 light strip captures the music going around it, syncing to the frequency and the beat. Keep pace with the rhythm and get all your senses stirred up at a party!
Tapo L930-5 - light strip - LED - 13 W - 16 million colours
Light strip
Light Source Type
LED
Usage Modes
Away
Wattage
13 W
Colour of Illumination
16 million colours
Luminous Power
1000 lumens
Dimmable
Intelligent Assistant
Alexa, Google Assistant, Siri - indirect
Platform
Apple HomeKit
Communications Technology
Wi-Fi
AC 100 - 240 V
Frequency Required
50/60 Hz
Light strip
Usage Modes
Away
50 colour zones, cuttable, 3M adhesive tape mounting, power on/off timer, lighting schedules, remote controlled, app-controlled, voice control, flexible, Wi-Fi (2.4 GHz) controlled
Light Source
LED
Built-in LED Lamp
Wattage
13 W
16 million colours
Luminous Power
1000 lumens
Dimmable
Lifetime
50000 hours
Preset modes, 1%-100% dimmable, music sync, white LED
Power Requirements
AC 100 - 240 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Hub
Not needed
Platform
Apple HomeKit
Compatible Application
Tapo app
Wi-Fi
Voice Controlled
Indirect
Product Material
Polyurethane (PU)
RoHS, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC, JRF, IC, VCCI, RCM, NCC, BSMI
1 cm
0.3 cm
Length
5 m
649 g
23.15 cm x 6.85 cm x 20.45 cm
-15 °C
Type: Light strip
Compatible With: Alexa
Brand: TP LINK
