TP LINK Tapo L630 GU10 Smart Bulb (colour) 4-Pack
Quicklinx: H0P0WS00 Mfr#: TAPO L630(4-PACK)
Type: Light bulb
Compatible With: Alexa
Hurry, only 3 left in stock!
£27.49 ex VAT
£32.98 inc VAT
16 Million Colours -Shape the amazing vibe by picking the lights from a wide array of colours, even dim to any brightness you desire for the perfect atmosphere.
White Tuneable - Adjust the colour temperature from 2,200 K to 6,500 K based on your changing needs.
High Lumen & Dimmable - Emits 350 lm light that is bright enough to shed lights on any object and could be dimmed from 1% to 100%.
GU10 Lamp Base - Compatible with any GU10 fixtures well. No extra burden for your first attempt.
Grouping - Control all the Tapo Smart Spotlights by just one click on App.
Energy Saving - Reduce energy use by operating energy savingly, without losing brightness or quality.
Remote Control - Instantly turn the spotlight on/off wherever you are via the Tapo App.
Schedule - Preset a fixed schedule to manage your smart devices automatically.
Timer - Create countdown timer lists for more precise time control.
Voice Control - Manage your smart spotlights with voice commands via Amazon Alexa or Google Assistant.
Easy Setup and Use - No hub required, set up quickly and manage easily through the free App
  • Efficient energy use
    With an energy efficiency class of E and consuming only 4 kWh per 1000 hours, this light bulb is designed for energy savings and efficiency, making it an eco-friendly choice for your home.
  • Versatile color options
    Offering 16 million colors and tunable white light, this bulb can adjust from a warm 2200 K to a cool 6500 K color temperature, allowing you to create the perfect ambiance for any occasion.
  • Smart control
    Equipped with Smart Wi-Fi technology, this bulb can be controlled via the Tapo app, with features like lighting schedules, power on/off timer, and remote control, providing convenience and customization at your fingertips.
  • Voice activation
    Compatible with Alexa and Google Assistant, this bulb allows for voice control, enabling you to adjust lighting with simple voice commands for a seamless smart home experience.
  • Long-lasting and reliable
    Designed for durability, the bulb boasts a lifetime of 15,000 hours and 15,000 switch cycles, ensuring long-lasting reliability and reducing the need for frequent replacements.
Tapo L630 - LED spot light bulb - GU10 - 3.7 W - 16 million colours/tunable white - 2200-6500 K (pack of 4)
Light Source Type
LED spot light bulb
Packaged Quantity
4 (specifications are for single item)
Usage Modes
Energy save
Socket Type
GU10
Wattage
3.7 W
Wattage Equivalent
50 W
Energy Efficiency Class
E
Colour of Illumination
Colour Temperature
2200-6500 K
Luminous Power
350 lumens
Beam Angle
40 degree(s)
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
AC 220 - 240 V
Frequency Required
50/60 Hz
Packaged Quantity
Usage Modes
Energy save
Light Source
LED spot light bulb
Socket Type
GU10
Wattage
3.7 W
Wattage Equivalent
50 W
E
Energy Consumption per 1000h
4 kWh
Colour Temperature
2200-6500 K
Colour Rendering Index
80
Luminous Power
350 lumens
Beam Angle
40 degree(s)
Warm-Up Time
1 sec
Dimmable
Lifetime
15000 hours
Switch Cycles
15000
10%-100% dimmable, voice control, remote controlled, lighting schedules, power on/off timer, Wi-Fi (2.4 GHz) controlled, Smart Wi-Fi technology
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.2 Watt
Internet of Things (IoT)
Hub
Not needed
Compatible Application
Tapo app
Voice Controlled
Indirect
RoHS, ERP, RCM, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
5.52 cm
Diameter
5 cm
Type: Light bulb
Brand: TP LINK
