16 Million Colours -Shape the amazing vibe by picking the lights from a wide array of colours, even dim to any brightness you desire for the perfect atmosphere.
White Tuneable - Adjust the colour temperature from 2,200 K to 6,500 K based on your changing needs.
High Lumen & Dimmable - Emits 350 lm light that is bright enough to shed lights on any object and could be dimmed from 1% to 100%.
GU10 Lamp Base - Compatible with any GU10 fixtures well. No extra burden for your first attempt.
Grouping - Control all the Tapo Smart Spotlights by just one click on App.
Energy Saving - Reduce energy use by operating energy savingly, without losing brightness or quality.
Remote Control - Instantly turn the spotlight on/off wherever you are via the Tapo App.
Schedule - Preset a fixed schedule to manage your smart devices automatically.
Timer - Create countdown timer lists for more precise time control.
Voice Control - Manage your smart spotlights with voice commands via Amazon Alexa or Google Assistant.
Easy Setup and Use - No hub required, set up quickly and manage easily through the free App
Efficient energy use
With an energy efficiency class of E and consuming only 4 kWh per 1000 hours, this light bulb is designed for energy savings and efficiency, making it an eco-friendly choice for your home. -
Versatile color options
Offering 16 million colors and tunable white light, this bulb can adjust from a warm 2200 K to a cool 6500 K color temperature, allowing you to create the perfect ambiance for any occasion. -
Smart control
Equipped with Smart Wi-Fi technology, this bulb can be controlled via the Tapo app, with features like lighting schedules, power on/off timer, and remote control, providing convenience and customization at your fingertips. -
Voice activation
Compatible with Alexa and Google Assistant, this bulb allows for voice control, enabling you to adjust lighting with simple voice commands for a seamless smart home experience. -
Long-lasting and reliable
Designed for durability, the bulb boasts a lifetime of 15,000 hours and 15,000 switch cycles, ensuring long-lasting reliability and reducing the need for frequent replacements.
- Tapo L630 - LED spot light bulb - GU10 - 3.7 W - 16 million colours/tunable white - 2200-6500 K (pack of 4)
- Light Source Type
- Packaged Quantity
- 4 (specifications are for single item)
- Usage Modes
- Energy save
- Socket Type
- GU10
- Wattage
- 3.7 W
- Wattage Equivalent
- 50 W
- Energy Efficiency Class
- E
- Colour of Illumination
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 350 lumens
- Beam Angle
- 40 degree(s)
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50/60 Hz
- Packaged Quantity
- Usage Modes
- Energy save
Light Source
- Socket Type
- GU10
- Wattage
- 3.7 W
- 50 W
- E
- Energy Consumption per 1000h
- 4 kWh
- 2200-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 350 lumens
- Beam Angle
- 40 degree(s)
- Warm-Up Time
- 1 sec
- Dimmable
- Lifetime
- 15000 hours
- Switch Cycles
- 15000
- 10%-100% dimmable, voice control, remote controlled, lighting schedules, power on/off timer, Wi-Fi (2.4 GHz) controlled, Smart Wi-Fi technology
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50/60 Hz
- Power Consumption Stand by
- 0.2 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Compatible Application
- Tapo app
- Voice Controlled
- Indirect
- RoHS, ERP, RCM, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 5.52 cm
- Diameter
- 5 cm
- 0 °C
- 40 °C
