TP LINK Tapo L610 GU10 Smart Bulb (white / dimmable)
Quicklinx: H0NVWS00 Mfr#: TAPO L610
Type: Light bulb
Compatible With: Google Assistant, Alexa
£7.50 ex VAT
£9.00 inc VAT
Express delivery Order within the next 7 hours for delivery on Monday
2,700 K Warm Light- Set off a cozy and comfortable vibe for your home or any other public space
1~100% Dimmable - Dim to any brightness you desire for constantly-changing needs.
High Lumen - Emits 350 lm light that is bright enough to shed light on any object
GU10 Lamp Base - Compatible with any GU10 fixtures well. No extra burden for your first attempt.
Grouping - Control all the Tapo Smart Spotlights by just one click on App
Energy Saving - Reduce energy use by operating energy savingly, without losing brightness or quality.
Remote Control - Instantly turn the spotlight on/off wherever you are via the Tapo App.
Schedule - Preset a fixed schedule to manage your smart devices automatically.
Timer - Create countdown timer lists for more precise time control.
Voice Control - Manage your Smart Spotlights with voice commands via Amazon Alexa or Google Assistant.
Easy Setup & Use - No hub required, set up quickly and manage easily through the free App.
  • Efficient energy consumption
    The Tapo L610 operates at only 2.9 W while providing a bright output, making it a cost-effective choice for illuminating any room.
  • Easy voice control
    With compatibility for both Google Assistant and Alexa, controlling the Tapo L610 is simple and hands-free.
  • Flexible control options
    Users can manage settings through the Tapo app, enabling remote access and control over lighting schedules and timers.
  • Long-lasting design
    With a lifetime of 15,000 hours, this bulb is designed for durability and consistent performance.
  • Warm and inviting light
    The bulb emits a warm white illumination with a color temperature of 2700 K, creating a cozy atmosphere suitable for any setting.
Tapo L610 - light bulb / LED - GU10 - 2.9 W - warm white light - 2700 K
Light Source Type
Light bulb / LED
Usage Modes
Energy save
Socket Type
GU10
Wattage
2.9 W
Wattage Equivalent
50 W
Energy Efficiency Class
D
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
350 lumens
Beam Angle
40 degree(s)
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
AC 220 - 240 V
Frequency Required
50/60 Hz
Usage Modes
Energy save
Light Source
Light bulb / LED
Socket Type
GU10
Wattage
2.9 W
Wattage Equivalent
50 W
D
Energy Consumption per 1000h
3 kWh
Warm white light
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
350 lumens
Beam Angle
40 degree(s)
Warm-Up Time
1 sec
Dimmable
Lifetime
15000 hours
Switch Cycles
15000
Smart Wi-Fi technology, Wi-Fi (2.4 GHz) controlled, voice control, remote controlled, power on/off timer, lighting schedules
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.2 Watt
Internet of Things (IoT)
Hub
Not needed
Compatible Application
Tapo app
Voice Controlled
Indirect
Remote control
ERP, RoHS, RCM
51 g
Type: Light bulb
Compatible With: Alexa
Brand: TP LINK
Stock Status: While stocks last
Stock Status: Clearance
