2,700 K Warm Light- Set off a cozy and comfortable vibe for your home or any other public space
1~100% Dimmable - Dim to any brightness you desire for constantly-changing needs.
High Lumen - Emits 350 lm light that is bright enough to shed light on any object
GU10 Lamp Base - Compatible with any GU10 fixtures well. No extra burden for your first attempt.
Grouping - Control all the Tapo Smart Spotlights by just one click on App
Energy Saving - Reduce energy use by operating energy savingly, without losing brightness or quality.
Remote Control - Instantly turn the spotlight on/off wherever you are via the Tapo App.
Schedule - Preset a fixed schedule to manage your smart devices automatically.
Timer - Create countdown timer lists for more precise time control.
Voice Control - Manage your Smart Spotlights with voice commands via Amazon Alexa or Google Assistant.
Easy Setup & Use - No hub required, set up quickly and manage easily through the free App.
                Efficient energy consumptionThe Tapo L610 operates at only 2.9 W while providing a bright output, making it a cost-effective choice for illuminating any room.
                Easy voice controlWith compatibility for both Google Assistant and Alexa, controlling the Tapo L610 is simple and hands-free.
                Flexible control optionsUsers can manage settings through the Tapo app, enabling remote access and control over lighting schedules and timers.
                Long-lasting designWith a lifetime of 15,000 hours, this bulb is designed for durability and consistent performance.
                Warm and inviting lightThe bulb emits a warm white illumination with a color temperature of 2700 K, creating a cozy atmosphere suitable for any setting.
- Tapo L610 - LED spot light bulb - GU10 - 2.9 W - warm white light - 2700 K (pack of 4)
- Light Source Type
- Packaged Quantity
- 4 (specifications are for single item)
- Usage Modes
- Energy save
- Socket Type
- GU10
- Wattage
- 2.9 W
- Wattage Equivalent
- 50 W
- Energy Efficiency Class
- D
- Colour of Illumination
- Warm white light
- Colour Temperature
- 2700 K
- Luminous Power
- 350 lumens
- Beam Angle
- 40 degree(s)
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50/60 Hz
- Packaged Quantity
- Usage Modes
- Energy save
Light Source
- Socket Type
- GU10
- Wattage
- 2.9 W
- 50 W
- D
- Energy Consumption per 1000h
- 3 kWh
- Warm white light
- 2700 K
- Colour Rendering Index
- 80
- Luminous Power
- 350 lumens
- Beam Angle
- 40 degree(s)
- Warm-Up Time
- 1 sec
- Dimmable
- Lifetime
- 15000 hours
- Switch Cycles
- 15000
- 1%-100% dimmable, voice control, remote controlled, lighting schedules, power on/off timer, Wi-Fi (2.4 GHz) controlled, Smart Wi-Fi technology
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50/60 Hz
- Power Consumption Stand by
- 0.2 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Not needed
- Compatible Application
- Tapo app
- Voice Controlled
- Indirect
- RoHS, ERP, RCM, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 5.52 cm
- Diameter
- 5 cm
- 0 °C
- 40 °C
