TP LINK Tapo L610 GU10 Smart Bulb (white / dimmable) 2-Pack
Quicklinx: H0NWWS00 Mfr#: TAPO L610(2-PACK)
Type: Light bulb
Compatible With: Alexa, Google Assistant
£13.33 ex VAT
£15.99 inc VAT
Express delivery Order within the next 22 hours for delivery on Wednesday
2,700 K Warm Light- Set off a cozy and comfortable vibe for your home or any other public space
1~100% Dimmable - Dim to any brightness you desire for constantly-changing needs.
High Lumen - Emits 350 lm light that is bright enough to shed light on any object
GU10 Lamp Base - Compatible with any GU10 fixtures well. No extra burden for your first attempt.
Grouping - Control all the Tapo Smart Spotlights by just one click on App
Energy Saving - Reduce energy use by operating energy savingly, without losing brightness or quality.
Remote Control - Instantly turn the spotlight on/off wherever you are via the Tapo App.
Schedule - Preset a fixed schedule to manage your smart devices automatically.
Timer - Create countdown timer lists for more precise time control.
Voice Control - Manage your Smart Spotlights with voice commands via Amazon Alexa or Google Assistant.
Easy Setup & Use - No hub required, set up quickly and manage easily through the free App.
  • Efficient energy consumption
    The Tapo L610 operates at only 2.9 W while providing a bright output, making it a cost-effective choice for illuminating any room.
  • Easy voice control
    With compatibility for both Google Assistant and Alexa, controlling the Tapo L610 is simple and hands-free.
  • Flexible control options
    Users can manage settings through the Tapo app, enabling remote access and control over lighting schedules and timers.
  • Long-lasting design
    With a lifetime of 15,000 hours, this bulb is designed for durability and consistent performance.
  • Warm and inviting light
    The bulb emits a warm white illumination with a color temperature of 2700 K, creating a cozy atmosphere suitable for any setting.
Tapo L610 - LED spot light bulb - GU10 - 2.9 W - warm white light - 2700 K (pack of 2)
Light Source Type
LED spot light bulb
Packaged Quantity
2 (specifications are for single item)
Usage Modes
Energy save
Socket Type
GU10
Wattage
2.9 W
Wattage Equivalent
50 W
Energy Efficiency Class
D
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
350 lumens
Beam Angle
40 degree(s)
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
AC 220 - 240 V
Frequency Required
50/60 Hz
Packaged Quantity
Usage Modes
Energy save
Light Source
LED spot light bulb
Socket Type
GU10
Wattage
2.9 W
Wattage Equivalent
50 W
D
Energy Consumption per 1000h
3 kWh
Warm white light
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
350 lumens
Beam Angle
40 degree(s)
Warm-Up Time
1 sec
Dimmable
Lifetime
15000 hours
Switch Cycles
15000
1%-100% dimmable, voice control, remote controlled, lighting schedules, power on/off timer, Wi-Fi (2.4 GHz) controlled, Smart Wi-Fi technology
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.2 Watt
Internet of Things (IoT)
Hub
Not needed
Compatible Application
Tapo app
Voice Controlled
Indirect
RoHS, ERP, RCM, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
5.52 cm
Diameter
5 cm
51 g
Type: Light bulb
Brand: TP LINK
