TP LINK Tapo L510E Dimmable Smart Light Bulb E27
Quicklinx: FTNFWS00 Mfr#: Tapo L510E
Type: Light bulb
Compatible With: Alexa, Google Assistant
19 left in stock
£6.66 ex VAT
£7.99 inc VAT
Manage the lighting at your fingertips to create the perfect atmosphere in your home at any time with the Tapo L510E smart Wi-Fi lightbulb.
Found your favorite lighting for watching movies? Save it as a setting you can simply select for future movie nights.
Create a regular schedule to turn on/off with the brightness you set and automatically activate your light according to your time zone.
Manage the lights with your voice commands as Tapo works with Amazon Alexa and Google Assistant. Take your phone out for the pocket and open the Tapo app to control your light remotely. Tapo L510E allows you to automatically simulate someone being at home to frighten away unwanted visitors.
  • Adjust with ease
    Manage the lighting at your fingertips to create the perfect atmosphere in your home at any time.
  • Preset for convenience
  • Set your times
    Create a regular schedule to turn on/off with the brightness you set.
  • Sunrise and sunset modes
    Automatically activate your light according to your time zone.
  • Voice control
    Mange the lights with your voice commands as Tapo works with Amazon Alexa and Google Assistant.
  • Remote control
  • Away mode
    Automatically simulate someone being at home to frighten away unwanted visitors.
Tapo L510E - LED light bulb - E27 - 8.7 W - 2700 K
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/683005
Light Source Type
LED light bulb
Usage Modes
Sunrise, sunset, away
Socket Type
E27
Wattage
8.7 W
Energy Efficiency Class
F
Colour Temperature
2700 K
Luminous Power
806 lumens
Beam Angle
220 degree(s)
Dimmable
Intelligent Assistant
Google Assistant, Alexa
Platform
Tapo
Communications Technology
Wi-Fi
AC 220 - 240 V
Frequency Required
50/60 Hz
Usage Modes
Light Source
LED light bulb
Socket Type
E27
Wattage
8.7 W
F
Energy Consumption per 1000h
9 kWh
Lamp Current
73 mA
Colour Temperature
2700 K
Luminous Power
806 lumens
Beam Angle
220 degree(s)
Warm-Up Time
1 sec
Dimmable
Switch Cycles
15000
Android compatible, iOS compatible, voice control, controlled via Wi-Fi, delay timer, remote controlled, light scheduling
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.14 watt
Internet of Things (IoT)
Hub
Not needed
Platform
Tapo
Compatible Application
Tapo app
Wi-Fi
RoHS, ERP, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Diameter
60 mm
Length
115 mm
68 g
Type: Light bulb
Brand: TP LINK
Stock Status: While stocks last
Stock Status: Clearance
