TP LINK Tapo H100 Smart IoT Hub with Chime
Quicklinx: H43MWS00 Mfr#: Tapo H100
Type: Smart hub
Compatible With: [N/A]
26 In Stock
£15.83 ex VAT
£18.99 inc VAT
Whole-Home Coverage - Keep sub-devices connected at all times through the robust wireless network.
Low-Power Wireless Protocol - Make connected devices work energy-efficiently, promising longer standby time.
Smart Alarm - Coordinates with Tapo smart sensors to warn of danger or deter intruders.
Smart Doorbell - Pair it with Tapo Smart Button to build your smart doorbell system, plus 19 ringtones to choose from.
Tapo Ecology - Connect with up to 64 smart devices for an immersive and comprehensive smart home experience.
Reliable Long-Range Connections -The Tapo Hub transmits signals on a less-crowded, lower frequency broadband, allowing it to reliably reach devices in every corner of your house without interference.
19 Ringtones - Choose from a variety of ringtones to find the perfect chime for your customized scenarios.
Adjustable Sound - Adjust the volume to 4 different levels (Loud, Normal, Quiet, or Silent) to suit your needs.
All Devices in One Hub - Each Tapo Hub can connect up to 64 Tapo devices throughout your home Build and manage your smart home ecosystem with ease.
  • A low-power way to connect everything
    The Tapo Hub is the heart of your Tapo smart home, connecting devices like smart sensors, switches and buttons, using an ultra-low power wireless protocol. This technology helps battery-powered devices last longer.
  • Reliable long-range connections
  • Smart actions with sensors, switches and buttons
    With Tapo Smart Hub H100, you can trigger a Shortcut or control Tapo devices (such as smart plugs, smart lights and smart switches) based on sensor detection or with a button press.
  • 19 ringtones
  • Adjustable sound
    Adjust the volume to 3 different levels (Loud, Normal, Quiet) to suit your needs.
  • All devices in one hub
    Each Tapo Hub can connect up to 64 Tapo devices throughout your home. Build and manage your smart home ecosystem with ease.
Tapo H100 V1 - smart hub - with chime - Wi-Fi
Smart hub
Environment
Indoor
Functions
Doorbell, alarm control
Integrated Components
Speaker
Power Source
Power socket
Max Supported Devices
64
Wireless - Wi-Fi
Siren Sound Level
90 dB
Frequency Band
2.4 Ghz, 868 MHz
6.25 cm x 5.1 cm x 7.2 cm
Smart hub
Environment
Indoor
Functions
Speaker
Power Source
Power socket
64
Wireless
Frequency Band
2.4 Ghz, 868 MHz
Siren Sound Level
90 dB
LED indicator, SYNC/silence button, 19 selectable ringtones, flame-retardant, push notification low power consumption
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
Wi-Fi
Product Material
Polycarbonate
AC 100/240 V
0.5 Watt
RoHS, PC UL94 V0, Plug and Play
6.25 cm
5.1 cm
7.2 cm
10 - 90% RH (non-condensing)
Type: Smart hub
Brand: TP LINK
