TP LINK Tapo D230S1 Smart Video Doorbell
Quicklinx: HDSGWS00 Mfr#: TAPO D230S1
Type: Smart doorbell
Compatible With: Google Assistant, Alexa
16 In Stock
£76.66 ex VAT
£91.99 inc VAT
Tapo Smart Battery Video Doorbell
2K 5MP Live View
Always know what happens in front of your door through the Tapo app. With the starlight sensor and 2K 5MP resolution, check all the fine details captured even in low-light environments.
Color Night Vision
With the embedded spotlight and starlight sensor, Tapo D230S1 reveals high-fidelity details and color at night.
Head-to-Toe View
With the camera’s ultra-wide FOV(160° Diagonal), Tapo 4:3 live view ensures users can check visitors from head-to-toe as close as 1m†, which shows more vertical details than other 16:9 doorbells'.
Flexible Placement, Flexible Views
Different wedge choices allow users to make the doorbell suits more placement scenarios. Users can also use wedges to adjust the views.
Longer Battery Life
The rechargeable and removable battery with a low-power protocol extends your usage.
Smart AI Detection and Notification
Smart AI algorithms identify people and cars, and notify users as needed.
Multiple Ways to Answer
With two-way audio or a recorded quick response, communicate directly with your deliveries through the Tapo app.
Flexible Storage Choice
Save recorded videos on the hub-installed microSD card§ (up to 512 GB) or by using Tapo Care cloud storage services (subscription required).
Anti-theft Alarm
Be alerted when someone trying to take the doorbell off with the anti-theft alarm function.
Water & Dust Resistant IP64
Operates well on rainy days and in damp environments.
  • 2K 5MP live view
    Always know what happens in front of your door through the Tapo app. With the starlight sensor and 2K 5MP resolution, check all the fine-details captured even in low-light environments.
  • Color night vision
  • Head-to-toe view
    With the camera's ultra-wide FOV (160° Diagonal), Tapo 4:3 live view ensures users can check visitors from head-to-toe as close as 1 m, which shows more vertical details than other 16:9 doorbells'
  • Flexible placement, flexible views
    Different wedge choices give users possibilities to make the doorbell suits more placement scenarios. Users can also use these wedges to adjust the views.
  • Longer battery life
  • Person and vehicles detection
    Powerful Al identifies people or vehicles, notifying users with filtered notifications.
  • Multiple ways to answer
Tapo D230S1 V1 - Video Doorbell Camera Kit - smart doorbell - 802.11b, 802.11g, 802.11n
Smart doorbell - with camera
Placing / Mounting
Wall-mounting
Functions
Camera, entry chime
Integrated Sensors
Motion sensor, light sensor, alarm
Integrated Components
Microphone, speaker
Power Source
Intelligent Assistant
Alexa, Google Assistant
Wireless - 802.11b, 802.11g, 802.11n
Frequency Band
2.4 Ghz
Camera
Max Resolution 2560 x 1920 - audio - Day&Night
Functions
Camera, entry chime
Microphone, speaker
Integrated Sensors
Power Source
Placing / Mounting
Wall-mounting
Wireless
Frequency Band
2.4 Ghz
Smart notification, 2-way audio, selectable ringtones, LED indicator AES encryption, Internet Control Message Protocol (ICMP), DNS support, HTTPS support, TCP support, UDP support, TCP/IP support
Internet of Things (IoT)
Hub
Included
Hub Compatibility
Tapo H200
Compatible Application
Tapo app
Camera
Day & Night Functionality
Audio Support
Max Digital Video Resolution
2560 x 1920
5 megapixels resolution, 4:3 aspect ratio, Smart AI Detection, Colour Night Vision, 160° field of view (diagonal), AI Person Detection, AI vehicle detection, 1/2.7 CMOS image sensor type, F 2.1 lens aperture, 15 fps
Rechargeable Battery
Rechargeable
Capacity (Ah)
6700 mAh
Battery Lifetime
180 days
Encryption Algorithm
128-bit AES, SSL, TLS, WPA, WPA2-PSK
Warranty
IP64, EAC, UKCA
Dimensions & Weight Details
Camera: 5.45 cm x 14.6 cm x 3.55 cm , Hub: 7.145 cm x 7.145 cm x 3.125 cm
-20 °C
45 °C
10 - 90% RH (non-condensing)
Compatible With: Alexa
Brand: TP LINK
