2K 3MP ultra-clear images, always know what happens in front of your door through the Tapo app. With the starlight sensor and 2K 3MP resolution, check all the fine details captured even in low-light environments. Colour Night Vision Reveals high-fidelity details and colour at night with the starlight sensor. Multiple ways to answer.
160 Ultra-Wide Diagonal FOV - Receive head-to-toe views even when visitors stand too close to the doorbell with a 160 ultra-wide diagonal FOV.
Enhanced security
Equipped with a 3 megapixels resolution and a wide 160° diagonal field of view, the Tapo D210 V1 doorbell camera captures clear, broad images, ensuring no detail goes unnoticed. Features like person and vehicle detection enhance security by focusing on the most relevant movements. -
Reliable connectivity
With support for 802.11b/g/n wireless protocols and a range of network support features including AES encryption, DHCP, and DNS support, this doorbell camera ensures a stable and secure connection to your home network. -
Intelligent integration
Compatible with the Tapo app and intelligent assistants like Alexa and Google Assistant, the Tapo D210 V1 offers seamless integration into your smart home ecosystem, allowing for easy monitoring and control. -
All-weather durability
Designed to withstand the elements, the Tapo D210 V1 is weatherproof with an IP65 rating, ensuring it operates effectively in a wide range of temperatures from -20°C to 45°C and in varying humidity conditions. -
Night vision capability
Featuring infrared light and a built-in spotlight, the doorbell camera provides clear footage around the clock with its day and night functionality, ensuring your home is monitored 24/7.
- Tapo D210 V1 - doorbell camera - 802.11b, 802.11n, 802.11g - with Tapo Doorbell Chime
- Product Type
- Doorbell camera - with camera
- Placing / Mounting
- Wall-mounting
- Functions
- Camera, entry chime
- Integrated Sensors
- Ambient light sensor, motion sensor, alarm
- Integrated Components
- Microphone, speaker
- Power Source
- Battery
- Intelligent Assistant
- Google Assistant, Alexa
- Bundled with
- Tapo Doorbell Chime
- Connectivity
- Wireless - 802.11b, 802.11n, 802.11g
- Frequency Band
- 2.4 Ghz
- Camera
- Max Resolution 2304 x 1296 - audio - Day&Night
- Camera Zoom
- 10x digital zoom
- Product Type
- Functions
- Power Source
- Battery
- Wall-mounting
- Bundled with
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 Ghz
- Push notification, weatherproof, 2-way audio, LED indicator, H.264 compression standard DHCP support, Internet Control Message Protocol (ICMP), AES encryption, DNS support, NTP support, UDP support, TCP support, HTTPS support, TCP/IP support
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Compatible Application
- Tapo app
Camera
- Day & Night Functionality
- Digital Zoom
- 10
- Audio Support
- Max Digital Video Resolution
- 2304 x 1296
- Video Modes
- 2K
- Wide Dynamic Range (WDR), reset button, Vehicle Detection, 3D digital noise reduction (DNR), motion detection, 135° field of view (horizontal), 109° field of view (vertical), Person Detection, built-in spotlight, 3 megapixels resolution, 1/3 CMOS image sensor type, infrared light, 160° field of view (diagonal), 15 fps, noise-cancellation microphone, F 1.18 lens aperture, 1.18mm focal length, doorbell button, anti-theft button
Flash Memory
- Supported Flash Memory Cards
- microSD
- Rechargeable Battery
- Rechargeable
- Technology
- Lithium Ion
- Capacity (Ah)
- 6400 mAh
- Battery Lifetime
- 180 days
- Included Accessories
- Mounting kit
- Encryption Algorithm
- SSL, TLS, WPA, 128-bit AES, WPA2-PSK
- FCC, RoHS, IP65, EAC, RCM, UKCA, R-NZ, Triman
- Dimensions & Weight Details
- Camera: 5 cm x 3.84 cm x 15 cm
- -20 °C
- 45 °C
- 10 - 90% RH (non-condensing)
