TP LINK Tapo D210 2K Video Doorbell with Chime
Quicklinx: HRJPWS00 Mfr#: Tapo D210
Type: Doorbell camera
Compatible With: Google Assistant, Alexa
£37.49 ex VAT
£44.98 inc VAT
Express delivery Delivered on Tuesday
2K 3MP ultra-clear images, always know what happens in front of your door through the Tapo app. With the starlight sensor and 2K 3MP resolution, check all the fine details captured even in low-light environments. Colour Night Vision Reveals high-fidelity details and colour at night with the starlight sensor. Multiple ways to answer.
160 Ultra-Wide Diagonal FOV - Receive head-to-toe views even when visitors stand too close to the doorbell with a 160 ultra-wide diagonal FOV.
  • Enhanced security
    Equipped with a 3 megapixels resolution and a wide 160° diagonal field of view, the Tapo D210 V1 doorbell camera captures clear, broad images, ensuring no detail goes unnoticed. Features like person and vehicle detection enhance security by focusing on the most relevant movements.
  • Reliable connectivity
    With support for 802.11b/g/n wireless protocols and a range of network support features including AES encryption, DHCP, and DNS support, this doorbell camera ensures a stable and secure connection to your home network.
  • Intelligent integration
    Compatible with the Tapo app and intelligent assistants like Alexa and Google Assistant, the Tapo D210 V1 offers seamless integration into your smart home ecosystem, allowing for easy monitoring and control.
  • All-weather durability
    Designed to withstand the elements, the Tapo D210 V1 is weatherproof with an IP65 rating, ensuring it operates effectively in a wide range of temperatures from -20°C to 45°C and in varying humidity conditions.
  • Night vision capability
    Featuring infrared light and a built-in spotlight, the doorbell camera provides clear footage around the clock with its day and night functionality, ensuring your home is monitored 24/7.
Tapo D210 V1 - doorbell camera - 802.11b, 802.11n, 802.11g - with Tapo Doorbell Chime
Doorbell camera - with camera
Placing / Mounting
Wall-mounting
Functions
Camera, entry chime
Integrated Sensors
Ambient light sensor, motion sensor, alarm
Integrated Components
Microphone, speaker
Power Source
Intelligent Assistant
Bundled with
Tapo Doorbell Chime
Wireless - 802.11b, 802.11n, 802.11g
Frequency Band
2.4 Ghz
Camera
Max Resolution 2304 x 1296 - audio - Day&Night
Camera Zoom
10x digital zoom
Functions
Camera, entry chime
Microphone, speaker
Integrated Sensors
Power Source
Placing / Mounting
Wall-mounting
Bundled with
Tapo Doorbell Chime
Wireless
Frequency Band
2.4 Ghz
Push notification, weatherproof, 2-way audio, LED indicator, H.264 compression standard DHCP support, Internet Control Message Protocol (ICMP), AES encryption, DNS support, NTP support, UDP support, TCP support, HTTPS support, TCP/IP support
Internet of Things (IoT)
Compatible Application
Tapo app
Camera
Day & Night Functionality
Digital Zoom
10
Audio Support
Max Digital Video Resolution
2304 x 1296
Video Modes
2K
Wide Dynamic Range (WDR), reset button, Vehicle Detection, 3D digital noise reduction (DNR), motion detection, 135° field of view (horizontal), 109° field of view (vertical), Person Detection, built-in spotlight, 3 megapixels resolution, 1/3 CMOS image sensor type, infrared light, 160° field of view (diagonal), 15 fps, noise-cancellation microphone, F 1.18 lens aperture, 1.18mm focal length, doorbell button, anti-theft button
Flash Memory
Supported Flash Memory Cards
microSD
Rechargeable Battery
Rechargeable
Lithium Ion
Capacity (Ah)
6400 mAh
Battery Lifetime
180 days
Mounting kit
Encryption Algorithm
SSL, TLS, WPA, 128-bit AES, WPA2-PSK
FCC, RoHS, IP65, EAC, RCM, UKCA, R-NZ, Triman
Dimensions & Weight Details
Camera: 5 cm x 3.84 cm x 15 cm
-20 °C
45 °C
10 - 90% RH (non-condensing)
Compatible With: Alexa
Brand: TP LINK
Stock Status: While stocks last
Stock Status: Clearance
