The Tapo C720 V1.6 from TP-Link is designed to offer security for your home or business. With its wide 153° diagonal field of view, this camera captures more of your property, ensuring comprehensive coverage with fewer blind spots. Night or day, the Tapo C720 V1.6 provides clear, detailed images thanks to its 2560 x 1440 resolution and infrared night vision capability, reaching up to 29.9 m.
Advanced AI detection technologies, including person, pet, and vehicle recognition, reduce false alarms and focus on-the-movements that matter. Weather is never an issue, as the camera's IP65 rating certifies it as dustproof and weatherproof, suitable for any environment. Additionally, the Tapo C720 V1.6 integrates seamlessly into your smart home system, supporting Wi-Fi connectivity and compatible with Alexa and Google Assistant for effortless control and monitoring. Whether you're looking to enhance your home security or monitor your business, the Tapo C720 V1.6 offers the features and reliability you need.
                Wide coverageWith an angular field of view reaching 153 degrees diagonally, 134 degrees horizontally, and 77.6 degrees vertically, the Tapo C720 V1.6 ensures comprehensive coverage of your space, minimizing blind spots for enhanced security.
                Enhanced night visionEquipped with infrared LEDs, the Tapo C720 V1.6 offers clear night vision up to 29.9 m, ensuring your property is well-monitored even in complete darkness.
                Smart detection capabilitiesFeaturing advanced AI detection technologies, including person, pet, and vehicle recognition, the Tapo C720 V1.6 minimizes false alarms and provides accurate motion detection for effective monitoring.
                Robust outdoor readinessCertified with an IP65 rating, the Tapo C720 V1.6 is dustproof and weatherproof, making it ideal for outdoor installation in any climate, from -20 °C to 45 °C.
                Seamless connectivitySupporting Wi-Fi connectivity and compatible with IoT platforms like Alexa and Google Assistant, the Tapo C720 V1.6 offers easy integration into your smart home ecosystem for convenient control and monitoring.
- Tapo C720 V1.6 - network surveillance camera
- Network surveillance camera - fixed - dustproof / weatherproof
- Audio
- Yes: two-way audio capability, built-in speaker, built-in microphone
- Camera Mount Type
- Wall mount, ceiling mount
- 15.1 cm x 14.56 cm x 15.1 cm
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 2560 x 1440
- Frame Rate (max)
- 15 frames per second
- Motion Detection
- Video Modes
- 2K
- Optical Sensor Type
- CMOS - 1/3"
- Focal Length Control
- Fixed focal
- Focal Length
- 2.1 mm
- Lens Iris
- F/2.1
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, 2.4GHz radio
- Intelligent Assistant
- Google Assistant, Alexa
- 2800 lumens floodlight sensor, smart AI motion tagging, motion activated floodlight, Smart AI Detection, 270-degree motion detection angle, adjustable floodlight brightness, built-in siren (93 dB), 150° field of view, reset button, 5000°K colour temperature LEDs, Live View Control, 3D digital noise reduction (DNR), Wide Dynamic Range (WDR), noise-cancellation microphone, 3 x PIR motion sensors, ambient light sensor, AI Person Detection, AI Pet Detection, AI vehicle detection, AI Line Crossing Detection, AI Camera Tampering Detection, Snapshot notification, ONVIF support, LED indicator
- 2-year warranty
- Environmental Parameters (operating)
- -20 °C - 45 °C; 10 - 90% RH (non-condensing) relative humidity
- Audio Support
- Camera Mount Type
- Wireless
- 15.1 cm
- 14.56 cm
- 15.1 cm
Camera
- Colour - Day&Night - fixed - dustproof / weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 2560 x 1440
- Motion Detection
- Video Modes
- 2K
- Digital Zoom
- 12
- Infrared LEDs
- Infrared Distance
- 29.9 m
- Digital Video Capture Resolution
- 2560 x 1440
- Frame Rate (max)
Image Sensor
- CMOS 1/3"
Lens Construction
- Fixed focal
- Focal Length
- 2.1 mm
- Lens Iris
- F/2.1
- Horizontal Field of View (degree)
- 134
- Vertical Field of View (degree)
- 77.6
- Diagonal Field of View (degree)
- 153
- Network Interface
- Network Protocols
- RTSP
- Supported Memory Cards
- microSD Card
- Encryption Algorithm
- 128-bit AES, TLS, SSL, WPA, WPA2-PSK, WPA3
- Included Accessories
- Mounting hardware
- IP65, FCC, RoHS, RCM
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Technology
- Wi-Fi
- Limited warranty - 2 years
- -20 °C
- 45 °C
- Relative Humidity (operating)
- 10 - 90% RH (non-condensing)
