TP LINK Tapo C720 Outdoor Floodlight Cam
Quicklinx: HRJNWS00 Mfr#: Tapo C720
  • microSD Card
£81.66 ex VAT
£97.99 inc VAT
The Tapo C720 V1.6 from TP-Link is designed to offer security for your home or business. With its wide 153° diagonal field of view, this camera captures more of your property, ensuring comprehensive coverage with fewer blind spots. Night or day, the Tapo C720 V1.6 provides clear, detailed images thanks to its 2560 x 1440 resolution and infrared night vision capability, reaching up to 29.9 m.
Advanced AI detection technologies, including person, pet, and vehicle recognition, reduce false alarms and focus on-the-movements that matter. Weather is never an issue, as the camera's IP65 rating certifies it as dustproof and weatherproof, suitable for any environment. Additionally, the Tapo C720 V1.6 integrates seamlessly into your smart home system, supporting Wi-Fi connectivity and compatible with Alexa and Google Assistant for effortless control and monitoring. Whether you're looking to enhance your home security or monitor your business, the Tapo C720 V1.6 offers the features and reliability you need.
  • Wide coverage
    With an angular field of view reaching 153 degrees diagonally, 134 degrees horizontally, and 77.6 degrees vertically, the Tapo C720 V1.6 ensures comprehensive coverage of your space, minimizing blind spots for enhanced security.
  • Enhanced night vision
    Equipped with infrared LEDs, the Tapo C720 V1.6 offers clear night vision up to 29.9 m, ensuring your property is well-monitored even in complete darkness.
  • Smart detection capabilities
    Featuring advanced AI detection technologies, including person, pet, and vehicle recognition, the Tapo C720 V1.6 minimizes false alarms and provides accurate motion detection for effective monitoring.
  • Robust outdoor readiness
    Certified with an IP65 rating, the Tapo C720 V1.6 is dustproof and weatherproof, making it ideal for outdoor installation in any climate, from -20 °C to 45 °C.
  • Seamless connectivity
    Supporting Wi-Fi connectivity and compatible with IoT platforms like Alexa and Google Assistant, the Tapo C720 V1.6 offers easy integration into your smart home ecosystem for convenient control and monitoring.
Tapo C720 V1.6 - network surveillance camera
Network surveillance camera - fixed - dustproof / weatherproof
Audio
Yes: two-way audio capability, built-in speaker, built-in microphone
Camera Mount Type
Wall mount, ceiling mount
15.1 cm x 14.56 cm x 15.1 cm
Wireless
Camera
Colour - Day&Night
Max Resolution
2560 x 1440
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
2K
Optical Sensor Type
CMOS - 1/3"
Focal Length Control
Fixed focal
Focal Length
2.1 mm
Lens Iris
F/2.1
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, 2.4GHz radio
Intelligent Assistant
Google Assistant, Alexa
2800 lumens floodlight sensor, smart AI motion tagging, motion activated floodlight, Smart AI Detection, 270-degree motion detection angle, adjustable floodlight brightness, built-in siren (93 dB), 150° field of view, reset button, 5000°K colour temperature LEDs, Live View Control, 3D digital noise reduction (DNR), Wide Dynamic Range (WDR), noise-cancellation microphone, 3 x PIR motion sensors, ambient light sensor, AI Person Detection, AI Pet Detection, AI vehicle detection, AI Line Crossing Detection, AI Camera Tampering Detection, Snapshot notification, ONVIF support, LED indicator
Environmental Parameters (operating)
-20 °C - 45 °C; 10 - 90% RH (non-condensing) relative humidity
Audio Support
Camera Mount Type
Wireless
15.1 cm
14.56 cm
15.1 cm
Camera
Colour - Day&Night - fixed - dustproof / weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
2560 x 1440
Motion Detection
Video Modes
2K
Digital Zoom
12
Infrared LEDs
Infrared Distance
29.9 m
Digital Video Capture Resolution
2560 x 1440
Frame Rate (max)
Image Sensor
CMOS 1/3"
Lens Construction
Fixed focal
Focal Length
2.1 mm
Lens Iris
F/2.1
Horizontal Field of View (degree)
134
Vertical Field of View (degree)
77.6
Diagonal Field of View (degree)
153
Network Interface
Network Protocols
RTSP
Supported Memory Cards
microSD Card
Encryption Algorithm
128-bit AES, TLS, SSL, WPA, WPA2-PSK, WPA3
Mounting hardware
IP65, FCC, RoHS, RCM
Internet of Things (IoT)
Communications Technology
Wi-Fi
-20 °C
45 °C
Relative Humidity (operating)
Brand: TP LINK
