TP LINK Tapo C510W Outdoor Cam
Quicklinx: HGRNWS00 Mfr#: TAPO C510W
Compatible With: Alexa, Google Assistant
  • microSD Card
Hurry, only 2 left in stock!
£34.99 ex VAT
£41.98 inc VAT
With the higher resolution, Tapo C510W enhances your security by capturing more details compared with traditional 1080p. The full-color night vision reveals full-color images with built-in spotlights even at night. It provides 360° horizontal and 130° vertical view range to capture everything around.
Tapo C510W tracks motion with high-speed rotation, ensuring you to keep an eye on more vital areas. Smart AI identifies a person, notifying you as needed. You can also set up customizable activity zones or boundaries to only receive alerts that matter.
Record your own audio as an alarm and adjust the brightness for your customized use. Tapo C510W offers excellent waterproof and dustproof performance for outdoor scenarios.
  • 360° visual coverage
  • Full-color mode
    Two built-in spotlights enable Tapo C510W to capture full-color images for enhanced security.
  • Infrared mode
    Provides a visual distance of up to 98ft at night while also helping you save more energy with spotlights off.
  • Smart mode
    Lights up the environment and automatically switches to full-color mode to provide more details when a person or motion is detected.
  • 2K resolution, see every detail
  • Smart motion tracking
  • Multiple detection
    Customize your detection and keep an eye on what matters.
  • Customizable sound and light alarm
    Record your own audio as an alarm to extend your usages. The ultra-bright and adjustable light is also supported to frighten unwanted visitors away.
  • Secure local and cloud storage
    Save recorded videos to a microSD card or by using Tapo Care cloud services.
  • IP65 water and dust resistant
    Offers excellent waterproof and dustproof performance for outdoor scenarios.
  • Two-way audio
    Communicate directly with the outdoors for your convenience.
  • Physical privacy mode
    Maintains your privacy with the lens physically blocked by the housing.
  • Voice activated
    Enjoy your smart life and keep an eye on your vital areas with Alexa and Google Assistant supported.
Tapo C510W V1 - network surveillance camera
Network surveillance camera - pan / tilt - outdoor - dustproof / weatherproof
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
Camera Mount Type
Wall mount, ceiling mount, pole mount
12.38 cm x 12.3 cm x 9 cm
Wireless
Camera
Colour - Day&Night
Max Resolution
2304 x 1296
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
2K
Optical Sensor Type
CMOS - 1/2.8" - 3 MP
Focal Length Control
Fixed focal
Focal Length
3.9 mm
Lens Iris
F/2.0
Panning Range (degree)
360
Tilting Range (degree)
130
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, 2.4GHz radio
Intelligent Assistant
Alexa, Google Assistant - indirect
Voltage
AC 100-240 V
Colour Night Vision, Person Detection, clips notification, Snapshot notification, reset button, LED indicator, Smart AI Detection, alarm function, Smart Activity Zones, Privacy mode
Environmental Parameters (operating)
-30 °C - 60 °C; 10 - 90% RH (non-condensing) relative humidity
Audio Support
Camera Mount Type
Wireless
12.38 cm
12.3 cm
9 cm
Camera
Colour - Day&Night - pan / tilt - outdoor - dustproof / weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
2304 x 1296
Motion Detection
Video Modes
2K
Infrared LEDs
Infrared Distance
30 m
Digital Video Capture Resolution
2304 x 1296
Frame Rate (max)
Image Sensor
3 MP CMOS 1/2.8"
Lens Construction
Fixed focal
Focal Length
3.9 mm
Lens Iris
F/2.0
Panning
Range (degree)
360
Tilting
Range (degree)
130
Network Interface
Network Protocols
SSL, TLS, TCP/IP, ICMP, DNS, HTTPS, UDP/IP
Supported Memory Cards
microSD Card
Anchors, mounting bracket, mounting template, screws, waterproof seal
IP65, AES-128, WPA, WPA2-PSK, FCC, RoHS, RCM
Power adapter - external AC 100-240 V (50/60 Hz)
Internet of Things (IoT)
Compatible Application
Tapo app
Communications Type
Cloud
Communications Technology
Wi-Fi
Voice Controlled
Indirect
-30 °C
60 °C
Relative Humidity (operating)
Brand: TP LINK
