TP LINK Tapo C500 'Pan & Tilt' Outdoor Cam
Quicklinx: HCBHWS00 Mfr#: Tapo C500
1080p Full HD Live View-Reveals clear and sharp images with more details.
Person Detection and Motion Tracking-Smart AI identifies a person while tracking motion with high-speed rotation, notifying users as needed.
360° Visual Coverage-Provides 360° horizontal & 130° vertical range to cover every corner.
Night Vision (up to 98 ft)-Ensures your safety by providing a clear visual distance of up to 98 ft even in total darkness.
IP65 Weatherproof-Offers excellent waterproof and dustproof performance for outdoor scenarios.
Multiple Installation Options-Use the mounting screws, template and loops‡ to install on any wall, ceiling or pole for the perfect view—wherever you want.
Flexible Storage Choices-Save recorded videos to an installed microSD card(up to 512 GB)†, or use Tapo Care** cloud storage service.
Customizable Sound Alarm-Record your customized audio as an alarm to extend your usages.
Physical Privacy Mode-Maintains your privacy with the lens physically blocked by the housing.
Two-Way Audio-Enables communication through a built-in microphone and speaker.
  • Person detection and motion tracking
  • 1080p Full HD, clear every second
    Capture more details to make every moment shine.
  • IP65 water and dust resistant
  • Customizable sound alarm
Tapo C500 V1 - network surveillance camera
Network surveillance camera - fixed - indoor, outdoor - dust resistant / water resistant
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
Camera Mount Type
Ceiling mount
12.38 cm x 12.3 cm x 9 cm
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
1/3"
Focal Length Control
Fixed focal
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, 2.4GHz radio
Intelligent Assistant
Alexa, Google Assistant
Voltage
AC 100-240 V
Person Detection, reset button, LED indicator, motion detection
Environmental Parameters (operating)
-30 °C - 60 °C; 10 - 90% RH (non-condensing) relative humidity
Audio Support
Camera Mount Type
Ceiling mount
Wireless
12.38 cm
12.3 cm
9 cm
Camera
Colour - Day&Night - fixed - indoor, outdoor - dust resistant / water resistant
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
15 m
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
Image Sensor
1/3"
Lens Construction
Fixed focal
Network Interface
Network Protocols
TCP/IP, ICMP, DNS, HTTPS, UDP/IP
Anchors, mounting template, mounting bracket, screw, power adapter, waterproof seal plug
WPA, WPA2-PSK, AES-128, SSL, TLS, RoHS, RCM, FCC
Power adapter AC 100-240 V (50/60 Hz)
Internet of Things (IoT)
-30 °C
60 °C
Relative Humidity (operating)
