1080p Full HD Live View-Reveals clear and sharp images with more details.
Person Detection and Motion Tracking-Smart AI identifies a person while tracking motion with high-speed rotation, notifying users as needed.
360° Visual Coverage-Provides 360° horizontal & 130° vertical range to cover every corner.
Night Vision (up to 98 ft)-Ensures your safety by providing a clear visual distance of up to 98 ft even in total darkness.
IP65 Weatherproof-Offers excellent waterproof and dustproof performance for outdoor scenarios.
Multiple Installation Options-Use the mounting screws, template and loops‡ to install on any wall, ceiling or pole for the perfect view—wherever you want.
Flexible Storage Choices-Save recorded videos to an installed microSD card(up to 512 GB)†, or use Tapo Care** cloud storage service.
Customizable Sound Alarm-Record your customized audio as an alarm to extend your usages.
Physical Privacy Mode-Maintains your privacy with the lens physically blocked by the housing.
Two-Way Audio-Enables communication through a built-in microphone and speaker.
Person detection and motion tracking
Smart AI identifies a person while tracking motion with high-speed rotation, notifying users as needed. -
1080p Full HD, clear every second
Capture more details to make every moment shine. -
IP65 water and dust resistant
Offers excellent waterproof and dustproof performance for outdoor scenarios. -
Customizable sound alarm
- Tapo C500 V1 - network surveillance camera
- Network surveillance camera - fixed - indoor, outdoor - dust resistant / water resistant
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- Camera Mount Type
- Ceiling mount
- 12.38 cm x 12.3 cm x 9 cm
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 15 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- 1/3"
- Focal Length Control
- Fixed focal
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, 2.4GHz radio
- Intelligent Assistant
- Alexa, Google Assistant
- Voltage
- AC 100-240 V
- Person Detection, reset button, LED indicator, motion detection
- Environmental Parameters (operating)
- -30 °C - 60 °C; 10 - 90% RH (non-condensing) relative humidity
- Audio Support
- Camera Mount Type
- Ceiling mount
- Wireless
- 12.38 cm
- 12.3 cm
- 9 cm
Camera
- Colour - Day&Night - fixed - indoor, outdoor - dust resistant / water resistant
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Infrared LEDs
- Infrared Distance
- 15 m
- Digital Video Capture Resolution
- 1920 x 1080
- Frame Rate (max)
Image Sensor
- 1/3"
Lens Construction
- Fixed focal
- Network Interface
- Network Protocols
- TCP/IP, ICMP, DNS, HTTPS, UDP/IP
- Included Accessories
- Anchors, mounting template, mounting bracket, screw, power adapter, waterproof seal plug
- WPA, WPA2-PSK, AES-128, SSL, TLS, RoHS, RCM, FCC
- Power Device
- Power adapter AC 100-240 V (50/60 Hz)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- -30 °C
- 60 °C
- Relative Humidity (operating)
- 10 - 90% RH (non-condensing)
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HCBH 051117 Condition: Customer return - item has been opened but is in excellent condition |
£24.29 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
