TP LINK Tapo C410 Camera Kit
Quicklinx: HV1LWS00 Mfr#: Tapo C410KIT
  • microSD Card
£41.66 ex VAT
£49.99 inc VAT
  • Wire-Free, Installs Almost Anywhere: Eliminates the need for outlets and enables flexible placement. Add security to your home, wherever, whenever.
  • Superior 2K 3MP Visuals: Capture every detail in crystal-clear 2K resolution, with advanced algorithms ensuring perfect exposure day and night.
  • Color Night Vision: See the night in vivid colors with the large aperture lens and built-in spotlights effective up to 30 feet (9m).
  • Extended Battery Life: With up to 180 days of security on a single charge, the Tapo C410 minimizes maintenance.
  • Flexible Storage Options: Choose from local microSD storage up to 512GB or the secure Tapo Care cloud service for additional peace of mind.
  • Smart Person Detection: Get alerts when a person is detected, reducing false alerts and unnecessary notifications.
  • Intelligent Phone Notifications: Customize activity zones for precise motion detection and phone alerts, focusing on what truly matters.
  • IP65 Weatherproof: Offers excellent waterproof and dustproof performance for outdoor scenarios.
  • Effortless installation
    With its wire-free design and comprehensive mounting kit, including ceiling, table, and wall mounts, setting up the Tapo C410 KIT V1 is straightforward, ensuring you can secure your home or office without the need for professional installation.
  • Advanced surveillance technology
    Equipped with Starlight Technology and a high-performance Progressive Scan CMOS sensor, the Tapo C410 KIT V1 delivers clear, detailed images even in low-light conditions, ensuring round-the-clock security.
  • Smart home integration
    Fully compatible with Alexa and Google Assistant, this camera allows for indirect voice control and seamless integration into your smart home ecosystem, making it easier than ever to monitor your space.
  • Reliable outdoor protection
    Designed to withstand the elements, the Tapo C410 KIT V1 features weatherproof protection and operates in a wide range of temperatures, from -20°C to 45°C, ensuring reliable surveillance in any weather condition.
  • Eco-friendly power solution
    Bundled with the Tapo A201 solar panel, this camera offers an eco-friendly power solution, reducing the need for frequent battery replacements and ensuring continuous operation without additional energy costs.
Tapo C410 KIT V1 - network surveillance camera - with Tapo A201 solar panel
Network surveillance camera - fixed - indoor, outdoor - weatherproof
Bundled with
Audio
Yes: built-in microphone, built-in speaker, two-way audio capability
Camera Mount Type
Table mount, wall mount, ceiling mount
8.9 cm x 6 cm x 6 cm
230 g
Wireless
Camera
Colour - Day&Night
Max Resolution
2304 x 1296
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
2K
Optical Sensor Type
Progressive Scan CMOS - 1/2.8" - 3 MP
Focal Length Control
Fixed focal
Focal Length
3.17 mm
Lens Iris
F/1.65
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, 2.4GHz radio
Platform
Tapo Care
Intelligent Assistant
Alexa, Google Assistant - indirect
1 - USB adapter cable
Built-in 2 spotlights, Person Detection, Push Notification, sound and light alarm, Starlight Technology, reset button, 3D digital noise reduction (DNR), Wide Dynamic Range (WDR), noise-cancellation microphone, built-in siren (94 dB), 110° field of view, Pet Detection, Vehicle Detection, light sensor, customised activity zone, wire-free design
Environmental Parameters (operating)
-20 °C - 45 °C; 10 - 90% RH (non-condensing) relative humidity
Audio Support
Camera Mount Type
Wireless
8.9 cm
6 cm
6 cm
230 g
Bundled with
Camera
Colour - Day&Night - fixed - indoor, outdoor - weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
2304 x 1296
Motion Detection
Video Modes
2K
Infrared LEDs
Infrared Distance
9.1 m
Digital Video Capture Resolution
2304 x 1296
Frame Rate (max)
Image Sensor
3 MP Progressive Scan CMOS 1/2.8"
Lens Construction
Fixed focal
Focal Length
3.17 mm
Lens Iris
F/1.65
Horizontal Field of View (degree)
111
Vertical Field of View (degree)
56
Diagonal Field of View (degree)
125
Network Interface
Network Protocols
TCP/IP, UDP/IP, ICMP, DNS, HTTPS
Ports
USB-C (power only) - 24-pin USB-C
Supported Memory Cards
microSD Card
Encryption Algorithm
128-bit AES, WPA, WPA2-PSK, TLS, SSL
Mounting kit
1 x USB adapter cable
IP65, FCC, DOE, CEC, RCM, KC, NCC, BSMI, NTRA
Solar panel - external 1.04 Watt
Lithium Ion 6400 mAh (up to 180 days)
Android 5.0 or later, Apple iOS 11 or later
Internet of Things (IoT)
Platform
Tapo Care
Compatible Application
Tapo app
Supported Host Device Platform
Android, iOS
Communications Type
Cloud
Communications Technology
Wi-Fi
Voice Controlled
Indirect
-20 °C
45 °C
Relative Humidity (operating)
Type: Indoor / Outdoor Camera
Compatible With: Alexa
Brand: TP LINK
