TP LINK Tapo C310 Outdoor Security Camera
Quicklinx: G0R8WS00 Mfr#: Tapo C310
Type: Outdoor Camera
Compatible With: Alexa, Google Assistant
  • microSD Card
29 In Stock
£26.66 ex VAT
£31.99 inc VAT
Outdoor Security Wi-Fi Camera
Motion Detection and Notifications
Receive instant notifications and check feeds when the motion is detected. This helps you protect your home day and night.
3MP Ultra-High Definition
With 3MP high resolution, Tapo C310 delivers vivid images helping identification and recognition from fay away.
Wired or Wireless Networking
Connect your camera to the network through Ethernet or Wi-Fi for more flexible installation.
IP66 Weatherproof
Helps Tapo C310 perform well even in harsh environments with rain and dust.
Two-Way Audio
Always be on site with two-way audio. Communicate with a delivery person for your convenience.
Secure and Convenient Local Storage
Stores 3MP video directly to a local microSD card, offering convenient access to your video footage.
Sharp Night Vision
Provides a visual distance of up to 98 ft (30 m) even in total darkness to always keep you safe.
Automatic Siren
The automatic siren system will trigger light and sound to frighten away unwanted visitors after the camera detects motion.
Dedicated Tapo App
Live view, playback, save clips and set up–all in one app.
  • Ultra-high-definition video: records every image in crystal-clear 3MP definition
    Wired or wireless networking: connect your camera to the network through Ethernet or Wi-Fi for more flexible installationAdvanced night vision: provides a visual distance of up to 98 ft (30m) even in total darknessMotion detection and notifications: notifies you when the camera detects movementSound and light alarm: trigger light and sound effects to frighten away unwanted visitorsTwo-way audio: enables communication through a built-in microphone and speakerSafe storage: locally stores up to 128 GB 3MP video on a microSD card, offering convenient access to your video footage
Tapo C310 - network surveillance camera
Network surveillance camera - fixed - outdoor - dustproof / weatherproof
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
14.23 cm x 10.34 cm x 6.43 cm
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
2304 x 1296
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
2304p
Optical Sensor Type
1/2.7" - 3 MP
Focal Length Control
Fixed focal
Focal Length
3.89 mm
Lens Iris
F/2.2
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Ethernet 10Base-T/100Base-TX/1000Base-T
Voltage
DC 9 V
Voice control, Push Notification, reset button, LED indicator, night vision, alarm function, built-in siren
Environmental Parameters (operating)
-20 °C - 45 °C; 10 - 90% (non-condensing) relative humidity
Audio Support
Wired, wireless
14.23 cm
10.34 cm
6.43 cm
Camera
Colour - Day&Night - fixed - outdoor - dustproof / weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
2304 x 1296
Motion Detection
Video Modes
2304p
Infrared LEDs
Infrared Distance
30 m
Video Capture
2304 x 1296 @ 15 fps
Image Sensor
3 MP 1/2.7"
Lens Construction
Fixed focal
Focal Length
3.89 mm
Lens Iris
F/2.2
Network Interface
Network Protocols
SSL, TLS
Ports
LAN - RJ-45
Supported Memory Cards
microSD Card
Mounting template, anchors, screws, waterproof seal, cable waterproof connectors
NCC, AES-128, WPA2-PSK, WPA-PSK, SSL, TLS, IP66
Power Requirements
DC 9 V - 0.6 A
Power adapter - external AC 120/230 V (50/60 Hz)
Android 4.4 or higher, Apple iOS 9 or later
-20 °C
45 °C
Relative Humidity (operating)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: G0R8 051230
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £22.55
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: TP LINK
Stock Status: Used Stock
