TP LINK Tapo C200 Pan & Tilt Cam
Quicklinx: FMZ9WS00 Mfr#: C200
Type: Indoor Camera
Compatible With: Alexa, Google Assistant
  • microSDHC Card
  • microSD Card
More than 50 In Stock
£19.99 ex VAT
£23.98 inc VAT
High-Definition Video
Records every image in crystal-clear 1080p definition
Pan and Tilt
360º horizontal and 114º vertical range
Advanced Night Vision
Provides a visual distance of up to 30 ft
Motion Detection and Notifications
Notifies you when the camera detects movement
Sound and Light Alarm
Trigger light and sound effects to frighten away unwanted visitors.
Two-Way Audio
Enables communication through a built-in microphone and speaker
Safe Storage
Locally stores up to 512GB on a microSD card, equal to 384 hours (16 days) of footage.
Voice Control
Free Up Your Hands with Voice Control: Works with the Google Assistant and Amazon Alexa.
  • Detects motion and sends you alerts right away
    Home burglary is the very thing we want to prevent. Set a camera towards the entrance of your home, garage, or basement to ensure the safety of your family and property. Receive a notification when the camera detects motion at home. It can be a notice of arriving package, or suspicious intrusion. Trigger light and sound effects to frighten away unwanted visitors.
  • Advanced night view helps guard you while you sleep
    Sleep safe at night. Let your camera watch over your house while you're fast asleep. The 850 nm infrared night vision supports automatic color switch filter in low light conditions with a visual distance of up to 30 ft.
  • Privacy mode and safe local storage ensures your privacy
    You can turn on Privacy Mode, which can physically close the lens of camera to further ensure the safety of privacy. Moreover, the local Micro SD card works to prevent any internet hacking incidents.
  • High definition video
    Capture every detail in crystal-clear 1080p definition. See exactly what happened in front of your camera any time that it was on. Know whether your kids are safe, well taken care of, or are getting into trouble.
  • Live view and two-way audio
    When you take a trip, you can still make sure your fur babies aren't getting into trouble, or that your sitter is taking good care of them. Two-way audio allows you to tell them that you miss them (or to stop them from sharing your food).
  • Get a detailed look at your room
    A wide range of coverage to capture every moment.
  • Share every memorable moment
    Adorable and amusing moments are worth of sharing, especially with loved ones far away. Keep them in the loop on your day to day and part of your life with every precious second you share.
Tapo C200 - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
8.66 cm x 8.5 cm x 11.77 cm
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
1/2.9"
Focal Length Control
Fixed focal
Focal Length
4 mm
Lens Iris
F/2.4
Panning Range (degree)
360
Tilting Range (degree)
114
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 9 V
Motion Detection Technology, alarm function, Privacy mode, Push Notification, microSDXC card slot, WEP, WPA, WPA2, WPA2-PSK, firmware upgradable
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Audio Support
Wireless
8.66 cm
8.5 cm
11.77 cm
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
2
Infrared Distance
9.14 m
Video Capture
1920 x 1080 @ 15 fps
Image Sensor
1/2.9"
Lens Construction
Fixed focal
Focal Length
4 mm
Lens Iris
F/2.4
Panning
Range (degree)
360
Tilting
Range (degree)
114
Network Interface
Network Protocols
SSL, TLS
Supported Memory Cards
microSDXC Card, microSD Card, microSDHC Card
Camera mount base, mounting bracket, power adapter, screws
IC, FCC, NCC
Power Requirements
DC 9 V
Power adapter - external AC 120/230 V (50/60 Hz)
Android 4.4 or higher, Apple iOS 9 or later
Relative Humidity (operating)
Type: Indoor Camera
Brand: TP LINK
