TP LINK Tapo C100 Spot Cam
Quicklinx: FMZ8WS00 Mfr#: C100
Type: Indoor Camera
Compatible With: Google Assistant, Alexa
  • microSD Card
  • microSDHC Card
More than 50 In Stock
£16.99 ex VAT
£20.38 inc VAT
When you are away home, there are always something you care about. This is where the smart camera functions. No matter your child is climbing the kitchen cabinet, or the pet is stealing snacks, Tapo C100 helps you stay with them anytime, anywhere.
Receive a notification whenever your camera detects motion and see a video clip of the motion for closer inspection. Also, you can personalize your own experiences by setting the motion detection zones to only capture what happens in the area that you choose.
  • Motion detection
  • Night vision
    Don't wake up your little ones when you crack open their doors to check on them. Watch over them from your phone with 30 ft of night vision. You'll have peace of mind, and they'll have a good night's sleep.
  • High-definition video
    1080p definition video provides more clarity and sharpness in pictures due to a higher number of pixels. This helps with identification and recognition from far away.
  • Two-way audio
    Communicate with a loved one through the built-in microphone and speaker.
  • Protect your privacy
    Your privacy is ensured with privacy mode and a local storage card.
  • Privacy mode
    Shut down surveillance to protect your privacy whenever you want.
  • Alarm system
    Not only will the camera send notifications to you when motion is detected, it'll also trigger lights and sounds as an alarm.
  • Share memorable moments
    Save the most unforgettable moments and share them with your loved ones. Tapo cameras are always there to help you record every memorable moment.
  • A tap leads to what matters most
    The free Tapo app puts everything you need at your fingertips.
Tapo C100 - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
6.76 cm x 5.48 cm x 9.89 cm
Wireless
Camera
Colour - Day&Night
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
1/3.2"
Focal Length Control
Fixed focal
Focal Length
3.3 mm
Lens Iris
F/2.0
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 9 V
Push Notification, reset button, WEP, WPA, WPA2-PSK, alarm function, Privacy mode, ONVIF support
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Audio Support
Wireless
6.76 cm
5.48 cm
9.89 cm
Camera
Colour - Day&Night - fixed
Digital Video Format
H.264
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
9.14 m
Frame Rate (max)
Image Sensor
1/3.2"
Lens Construction
Fixed focal
Focal Length
3.3 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
105
Network Interface
Network Protocols
SSL, TLS, TCP/IP, DHCP, ARP, ICMP, DNS, NTP, HTTP, HTTPS, UDP/IP, RTSP
Supported Memory Cards
microSDXC Card, microSD Card, microSDHC Card
Screws, mounting template
IC, FCC, NCC, AES-128
Power Requirements
DC 9 V
Power adapter - external AC 120/230 V (50/60 Hz)
Android 4.4 or higher, Apple iOS 9 or later
Relative Humidity (operating)
Type: Indoor Camera
Compatible With: Alexa
Brand: TP LINK
