TP LINK T2U Nano Network adapter USB 2.0 802.11ac
Quicklinx: FGGCWS00 Mfr#: ARCHER T2U NANO
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11n, IEEE 802.11g, IEEE 802.11a + 1 more
Form Factor: External
Compatibility: [N/A]
Type: Network adapter
  • IEEE 802.11n
38 In Stock
£8.95 ex VAT
£10.74 inc VAT
The Archer T2U Nano receives Wi-Fi signals on two separate bands. Supporting 256QAM technology increases 2.4 GHz data rate from 150 Mbps to 200 Mbps for 33% faster performance. 433 Mbps on 5 GHz is ideal for HD video streaming and lag-free online gaming, while 200 Mbps on 2.4 GHz is perfect for normal use such as web surfing with legacy devices.
  • Miniature design - plug in and forget
    With its miniature size and sleek design, users can insert the nano adapter into any USB port and leave it there, no matter when they are traveling or at home.
  • Travel size and Wi-Fi roaming - great choice for mobile surfing
    Growing public Wi-Fi services comes with one inconvenience - you might have to repeatedly select and connect to different Wi-Fi networks while moving. Archer T2U Nano supports Wi-Fi Roaming that helps your devices connect to the most suitable Wi-Fi automatically as you move, ensure your network is uninterrupted, and with its small, travel-size, Archer T2U Nano is undoubtedly a great choice for mobile surfing.
TP-Link Archer T2U Nano - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
1.5 cm x 1.86 cm x 0.7 cm
Wi-Fi 5
Data Transfer Rate
600 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac
Microsoft Windows XP/ 7 / 8 / 8.1 / 10, Apple MacOS X 10.9 - 10.13
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Data Transfer Rate
600 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, 16 QAM
Frequency Band
2.4 GHz, 5 GHz
Ad-Hoc Mode
Aerial
Antenna
Internal
Directivity
Omni-directional
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC, RoHS
Software Included
Drivers & Utilities
1.5 cm
1.86 cm
0.7 cm
10 - 90% (non-condensing)
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac
Brand: TP LINK
