TP LINK Smart WiFi Light Bulb B Dimming 2 Pack
Quicklinx: GLJBWS00 Mfr#: Tapo L510B (2-Pack)
Type: Light bulb
Compatible With: Alexa, Google Assistant
£11.66 ex VAT
£13.99 inc VAT
Express delivery Order within the next 13 hours for delivery tomorrow
Manage the lighting at your fingertips to create the perfect atmosphere in your home at any time with the Tapo L510E smart Wi-Fi lightbulb.
Found your favorite lighting for watching movies? Save it as a setting you can simply select for future movie nights.
Create a regular schedule to turn on/off with the brightness you set and automatically activate your light according to your time zone.
Manage the lights with your voice commands as Tapo works with Amazon Alexa and Google Assistant. Take your phone out for the pocket and open the Tapo app to control your light remotely. Tapo L510E allows you to automatically simulate someone being at home to frighten away unwanted visitors.
Dimmable Adjust with Ease
Dimmable Preset for Convenience
Schedule Set Your Times
Schedule Sunrise and Sunset Modes
Automatically activate your light according to your time zone
Voice Control
Mange the lights with your voice commands as Tapo works with Amazon Alexa and Google Assistant
Remote Control
Away Mode
Automatically simulate someone being at home to frighten away unwanted visitors
No Hub Required
Connect the L510E Light to your home Wi-Fi network, then you are all set. No need for extra hubs or other devices.
Energy Saving
Benefit from the advanced technology, the Tapo L510B Dimmable Lights consume less energy than normal LED lights.
Tapo Ecosystem
With one Tapo app, everything is under your control. Tapo ecosystem is able to turn your home into a truly smart one.
Tapo L510B V1 - light bulb
Light bulb
Dimmable
Communications Technology
Wi-Fi
Light bulb
Light Source
Dimmable
Internet of Things (IoT)
Wi-Fi
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: GLJB 051270
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £8.10
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Light bulb
Brand: TP LINK
Stock Status: Used Stock
