TP LINK Smart Wi-Fi Light Bulb Multicolor
Quicklinx: HLWTWS00 Mfr#: Tapo L535B
Type: Light bulb
Compatible With: Siri, Alexa, Google Assistant
Hurry, only 3 left in stock!
£8.33 ex VAT
£9.99 inc VAT
Express delivery Delivered on Tuesday
  • Extra Bright Smart Light Bulb - With 1055 lumens (75W Equivalent) of crisp, high-quality lighting, Tapo L535B is ideal for any home space requiring brighter lighting.
  • Millions of Colors - Easily design scenarios for your daily routine or activities by customizing the light brightness, light temperature, and colors–with millions of hues to choose from via the Tapo app.
  • Matter-Certified - With support for the Matter protocol, Tapo L535B can seamlessly interoperate with other certified products across platforms.
  • Schedule & Timer - Create a regular schedule to turn on/off with your chosen light effects.
  • Voice Control - Manage your smart lights with voice commands via Alexa, Siri, or Google Assistant.
  • Remote Control and Away Mode - Instantly turn connected devices on/off wherever you are via the Tapo app. Turn on away mode to simulate someone being at home.
  • Energy Monitoring - Monitor your connected devices' real-time power consumption and costs via the Tapo app.
  • No Hub Required - Connect directly to your home's secure Wi-Fi network—no need for a hub or extra equipment.
  • Efficient energy use
    With an energy efficiency class of E and consuming only 9 kWh per 1000h, this LED light bulb is designed for cost-effective illumination while providing a luminous power of 1055 lumens.
  • Smart control
    Equipped with Smart Wi-Fi technology, this bulb offers features such as away mode, color change, light scheduling, power monitoring, and remote control capabilities, all accessible through voice control or the Tapo app.
  • Versatile compatibility
    Seamlessly integrates with major intelligent assistants like Alexa, Google Assistant, and Siri, and is compatible with Amazon Alexa, Google Home App, and Tapo app for a comprehensive smart home experience.
  • Optimal lighting conditions
    Offers a wide beam angle of 220 degrees and a color temperature range of 2500-6500 K, allowing for multicolor light adjustments and dimmable settings to create the perfect ambiance.
  • Long-lasting and reliable
    Designed for durability, the bulb has a lifetime of 25,000 hours and can withstand up to 15,000 switch cycles, ensuring reliable lighting with minimal maintenance.
Tapo L535B V3 - LED light bulb - shape: A60 - B22 - 8.6 W - multicolour light - 2500-6500 K
Light Source Type
LED light bulb
Shape
A60
Socket Type
B22
Wattage
8.6 W
Wattage Equivalent
75 W
Energy Efficiency Class
E
Colour of Illumination
Multicolour light
Colour Temperature
2500-6500 K
Luminous Power
1055 lumens
Beam Angle
220 degree(s)
Dimmable
Intelligent Assistant
Siri, Google Assistant, Alexa - indirect
Platform
Tapo
Communications Technology
Wi-Fi
AC 220 - 240 V
Frequency Required
50/60 Hz
Light Source
LED light bulb
Shape
A60
Socket Type
B22
Wattage
8.6 W
Wattage Equivalent
75 W
E
Energy Consumption per 1000h
9 kWh
Multicolour light
Colour Temperature
2500-6500 K
Colour Rendering Index
80
Luminous Power
1055 lumens
Beam Angle
220 degree(s)
Warm-Up Time
1 sec
Dimmable
Lifetime
25000 hours
Switch Cycles
15000
Voice control, remote controlled, light scheduling, power on/off timer, away mode, Smart Wi-Fi technology, colour change, power monitoring
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.4 Watt
Internet of Things (IoT)
Hub
Not needed
Platform
Tapo
Compatible Application
Tapo app, Google Home App, Amazon Alexa
Wi-Fi
Voice Controlled
Indirect
RoHS, ERP, SAA, RCM, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, WPA-PSK, WPA2-PSK, UKCA, WPA3-SAE
Diameter
60 mm
Length
115 mm
65 g
-15 °C
Type: Light bulb
Compatible With: Alexa
Brand: TP LINK
Stock Status: While stocks last
Stock Status: Clearance
