TP LINK Single USB 2.0 Port Fast Ethernet Print Server
Quicklinx: 7G2FWS00 Mfr#: TL-PS110U
The TP-LINK TL-PS110U print server allows you to take the computer out of the loop while setting up a printing network. All that is needed is to connect the TL-PS110U to a printer via the USB port, connect the print server to your LAN, and you will be able to access your printer from any computer on the LAN.
TP-Link TL-PS110U - print server - USB 2.0
Print server
External
Interface (Bus) Type
USB 2.0
7.3 cm x 6.5 cm x 3 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Network / Transport Protocol
TCP/IP, IPX/SPX, AppleTalk, NetBEUI/NetBIOS, LPR/LPD, RAW, SMB
RAM
2 MB
IEEE 802.3, IEEE 802.3u, USB 2.0
UNIX, Novell NetWare 3.12 or later, Apple MacOS 8.0 or later, Linux, Microsoft Windows NT, Microsoft Windows 95/98/ME/2000/XP/Vista
Print server
External
USB 2.0
Wired
Cabling Type
Ethernet, Fast Ethernet
Remote Management Protocol
SNMP, Telnet, IPP, HTTP
Status Indicators
Port status, port transmission speed, status
Auto-sensing per device, DHCP support, E-mail alert, firmware upgradable
Processor / Memory
RAM
2 MB
Flash Memory
1 MB
1 x USB 2.0 - 4 pin USB Type A , 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
FCC
7.3 cm
6.5 cm
3 cm
50 °C
0 - 70%
7G2F C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
