The TP-LINK TL-PS110P print server allows you to take the computer out of the loop while setting up a printing network. All that is needed is to connect the TL-PS110P to a printer via the parallel port, connect the print server to your LAN, and you will be able to access your printer from any computer on the LAN.
- TP-Link TL-PS110P - print server - parallel - 10/100 Ethernet
- Print server
- Form Factor
- External
- Interface (Bus) Type
- Parallel
- Ports
- 10/100 Ethernet
- 5.9 cm x 5.2 cm x 2.2 cm
- Data Link Protocol
- 10Mb LAN, 100Mb LAN
- TCP/IP, AppleTalk, NetBEUI/NetBIOS, IP/IPX, LPR/LPD, SMB
- RAM
- 2 MB
- IEEE 802.3, IEEE 802.3u
- System Requirements
- UNIX, Novell NetWare 3.12 or later, Apple MacOS 8.0 or later, Linux, Microsoft Windows Vista, Microsoft Windows NT / 2000 / XP / 2003
- Designed For
- HP Color LaserJet 2500, 2500L, 2500Lse, 2500n, 2500tn, 2550n, 2605, 2605dn, 2605dtn, 3700, 3700d, 3700dn, 3700dtn, 3700n, 4500, 4500dn, 4500n, 4650, 4650dn, 4650dtn, 4650hdn, 4650n, 8550, 8550dn, 8550n; DesignJet 100, 600, 650c, 700, 750c; Deskjet 1120c
- Print server
- Form Factor
- External
- Parallel
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wired
- Ethernet, Fast Ethernet
- Remote Management Protocol
- Telnet, HTTP
- Status Indicators
- Port transmission speed, status
- DHCP support, manageable, E-mail alert, firmware upgradable
Processor / Memory
- RAM
- 2 MB
- Flash Memory
- 1 MB
- 1 x 100Base-TX - RJ-45
- Connections
- 1 x parallel - IEEE 1284 (EPP/ECP) - 36 PIN Centronics
- FCC
- OS Required
- 5.9 cm
- 5.2 cm
- 2.2 cm
- 0 °C
- 50 °C
- 0 - 70%
- Designed For
- HP Color LaserJet 2500, 2500L, 2500Lse, 2500n, 2500tn, 2550n, 2605, 2605dn, 2605dtn, 3700, 3700d, 3700dn, 3700dtn, 3700n, 4500, 4500dn, 4500n, 4650, 4650dn, 4650dtn, 4650hdn, 4650n, 8550, 8550dn, 8550n , HP DesignJet 100, 600, 650c, 700, 750c , HP Deskjet 1120c
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
