TP LINK SafeStream TL-R605 Gigabit Multi-WAN VPN Router
Quicklinx: G6WVWS00 Mfr#: TL-R605
£44.42 ex VAT
£53.30 inc VAT
TL-R605 supports IPSec/PPTP/L2TP VPN over IPSec/SSL protocols. With a powerful hardware design, the router supports and manages up to 20x LAN-to-LAN IPsec, 16x OpenVPN, 16x L2TP, and 16x PPTP VPN connections. One-click auto IPSec VPN greatly simplifies VPN configuration and facilitates network management and deployment while also securing and encrypting private site-to-site data communications traveling over the internet.
  • Omada SDN
    As the gateway that seamlessly integrates into the Omada Software Defined Networking (SDN) platform, TL-R605 allows for remote and centralized management, anywhere, anytime. Standalone management via the Web UI or app is also available to maximize convenience.
  • Hassle-free centralized cloud management
    100% centralized cloud management of whole network from different sites - all controlled from a single interface anywhere, anytime.
  • Up to four WAN Gigabit ports to optimize bandwidth usage
    Three freely interchangeable ports that can be set to either WAN or LAN allow the router to support up to four WAN ports to satisfy various internet access requirements through one device. The multi-WAN Load Balancing function distributes data streams according to the bandwidth proportion of every WAN port to raise the utilization rate of multi-line broadband.
  • Internet access management strategy
    Standardize users' online behavior and easily specify the internet access rights and strategies of employee via IP/MAC/URL Filtering and Access Control List (ACL). Captive Portal authentication facilitates network resource control by capturing, authenticating, and classifying user access. Appropriate network resources can also be allocated for particular users or guests.
TP-Link SafeStream TL-R605 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Performance
VPN throughput (IPSec): 41.5 Mbps
IPSec VPN tunnels: 20 , PPTP VPN tunnels: 16 , L2TP VPN tunnels: 16 , Concurrent sessions: 25000
Network / Transport Protocol
TCP/IP, PPTP, L2TP, NTP, ICMP/IP, IPSec, PPPoE, FTP, DHCP, DNS, SIPS, HTTP, HTTPs
Routing Protocol
IGMPv2, static IP routing, IGMPv3
Remote Management Protocol
SNMP
VoIP Protocols
H.323
NAT support, SPI, VPN passthrough, IP address filtering, firmware upgradable, LAN-to-LAN bridging, ACL support, DPD, virtual server support, DHCP server, reset button, bandwidth control, port triggering, SPIF, IP-MAC binding, DHCP client, Diagnostic Function, Ping of Death, IGMP proxy, Captive Portal, DHCP reservation, system log, ARP inspection, port filtering, PFS, ZTP, DoS protection, DMZ support, DynDNS, schedule reboot
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, UPnP
DC 9 V 0.85 A
15.8 cm x 10.1 cm x 2.5 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/ME/XP/Vista/7
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
SNMP
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, UPnP, FCC, RoHS
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Power, system, WAN, LAN
IP Telephony
VoIP Protocols
H.323
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
DC 9 V
Electric Current Required
0.85 A
15.8 cm
10.1 cm
2.5 cm
10 - 90% (non-condensing)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: G6WV 051317
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £30.58
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Router
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: Ethernet
Brand: TP LINK
Stock Status: Used Stock
